Everything posted by Jentz9517
I tightened until it bottomed out and just nice and snug until completely stable with no fluctuation the triade remained stable at 0.004 for the last two turns I guess a fair bit tighter than an atomizer
Probably I didn't really like pour it down the tube I loosened it with it. There's no signs of it. It was bad to the point I had to loosen the star point screws on the end to coax it out.
Good call
Mine are pretty good my friends that I set up were catching so I used scotchbrite but after looking closer the threads were ok his magnetic tab had to have upward tension on it slightly tugging it when unscrewing/screwing.. Very odd and pretty temperamental. Sorry to hear that! Once I got them tuned in the nano became my favorite. Fingers crossed you get it back soon! When you do get it put a little graphite on those threads. Ttys
Johara Try these for ss316l they run warmish and are great for mixed also JJSSv2.csv JJ_SSv1.csv
Try these for UD 316l. They are specific to that wire but are great with other brands too.. they are a bit hotter and work well with mixed/claptonJJSSv2.csv JJ_SSv1.csv
For different wires yah I need to delete that file it loaded wrong
I never have but there's YouTube videos I think on that, I saw a guy use a small precision screw driver at very edge but he ended up ruining them
My new one did it's the battery fitment it pushes against board or I should say the frame it sets in just try to position it toward the left more. It could be the wire too pushing against it squashed inbetween battery and board the new ones seem not to fit together so good. I have an earlier release and it's perfect
I am happy with 0.006 I doubt they used 90% of the value since they probably used a solid copper tap.. I am having good results with the curves I made YT.csv
Duo Escribe settings mod res, case analyzer profile presets from ecigdo.com https://drive.google.com/file/d/0B0iI0nMz_7c4MTBZc2c5bVNmTXM/view The second link is the 1300 Mah Lipo settings https://drive.google.com/file/d/0B0iI0nMz_7c4ZXJJLUROaE5Xdlk/view?usp=sharing
Well you are right 99% of the time in my book. We need a kudos button!
Is that the same as for the Duo Bill because I was thinking about using those . Right now I am using ecigdo.com which is titled "Duo" the analyzer and mod resistance seems to jive but the profiles are definately not
If by "factory" you mean Evolv default then yes it's different. I do not get good results with any of the provided profile presets I don't know if there is more than one floating around since another person said he had no issues? He may have different file? He didn't post up a link.
Sorry late response yes you would need it to be pretty consistent . I am just using the ones listed
Yes I'm certain it's what it needs since it goes of without a hitch on the other. It had been fired 1730 times before I bought from the kid and he ran mostly competition drippers on it so It's seen better days! Thanks a lot again Retird and VB
Thanks for jarring my memory. I have been away from escribe awhile and forgot the tell tale signs of a wonky 510 pin. The smy75 runs it well since it's nice and stiff but I need a better spring on the lostvape.
It fluctuates between 0.765-0.774 good call I never thought of that. My other device runs this clone very well, maybe because it has a stiff spring. I just screwed on my authentic and it reads within 1 rarely 2
do you know where I could get a replacement spring instead of sending device to lost vape?
Ya my new one did this also. I should have checked before post.
See pic below : I have an issue with "ohms too high prompt" and towards end of vape temp protection now on most pulls. I don't seem to have a very strong 510 spring ? Usually lost vape is notorious for stiff springs. my question where can I get one to fix this because as of now in atomizer analyzer it reads resistance without anything attached or could it be something else? Thanks Edit: my other device does the same thing so maybe it keeps last reading?
