Jentz9517
Everything posted by Jentz9517
  1. Maybe Jaquith will post his tutorial he gave me for you with a lot of helpful hints- sounds like you need to turn punch and preheat to zero
  2. Now that I think about it your right- a different set of circumstances caused me to believe it had to be manually reset- DELETE
  3. Notice with the newest escribe version that when leaving device monitor after setting charge current to zero it then returns to default current after returning from other tabs. Is this a feature or bug? Was nice having to manually reset when done testing in D.M.
  4. It works great with LV
  5. oh that's 32 platinum "laugh" no just a-1
  6. Actually it's that 26g Ti and 32 The 24 was supposed to come today but? Hoping Tomorrow - I am running exactly that but 545F - I am new to temp control but very impressed with your work and help - Can't Thank you enough! Oh and I'm almost done with the VapeMiser interview- good stuff
  7. I should have went with the 6ml version steamcrave Im filling the nano every 25-30 minutes haha. Thanks Again David
  8. Edit: good info under Reuleaux Mod Resistance Thread on lowering the soft cut off also max recharges stops charge at 4.19v and max puffs I believe 4.20v
  9. Hey David! Did you receive my note in your inbox ? It's not showing receipt? No rush..
  10. Let me get this right. So if my TCR was 0.006 I have to bring it down to 0.001 or just 0.005? And I think you mean 0.005 as the range is only 0.001-0.01. I also noticed in the temperature control results equivalents tab, it mentioned "To match it on a mod set to Titanium 1, adjust the temperature to ~210°C or ~410°F." and so I did. Seems a lot better than before. It was at 450F previously. What is this Equivalents tab suppose to be for? Oh....and thanks for the help.[/QUOTE] If your TCR is set to 0.006 and you think it's too hot, bring it down by 0.0005 to 0.0055 and see if that's cool enough. For Ti grade 1, 0.006 is on the high side. I use 0.0041 for Ti wire I got from unkamen and I've actually measured the resulting temperature to be very close to spot on. The equivalents tab on steam engine is for setting up mods that can't change TCR and are permanently set for Ni200. DNA 200 doesn't need that. [/QUOTE] So you are manually entering 0.0041 as the tcr for Unkamen under special ? Are you then adjusting the temp points on graph because I have had better success with using the 0.006 value nickel default I'm guess it is- I know you have explained but it seems inconsistent and fluctuates the resistance can you elaborate ? Thanks
  11. 900MAH.ecig direct from manufacturer
