Brandon
Everything posted by Brandon
  1. Device Monitor->Diagnostics->Set USB Charge Limit
  2. My son plays for Edgewood, We gave a lot of teams their only win last year
  3. @antyac I've Pm'd you with the information for the return.
  4. I think if you ask around, you'll find that they are. They are located in Hawaii.
  5. Miskol, Which version of SolidWorks are you using? The SolidWorks files will only open in 2015. EDIT: Saw your edit
  6. Macz is correct.
  7. In the beta's we used kapton at the battery connectors as an insulator. Not an elegant solution but an effective one. With the 3 point mounting, the likelihood of a case short seemed unlikely but never say never.
  8. Well, that's not good, thanks for the vid. Looks like we've got quite a bit of polishing to do.
  9. On the list and thank you!!
  10. I just did a search for '3s LifePO4 1200 mah' and it returned a large number of relatively small batteries. I can't say which is best but there seems to be quite a few out there.
  11. Thanks, I'll make a note of it and add it to the list of tutorial bugs.
  12. The battery in the betas is a FullyMax FB900HP-3S It is advertised at 10Wh but we've found it to be closer to 8.8Wh. Not surprising but... As for making and selling reference cases, that is the plan but I have no idea when those will be available. They will be tumbled raw aluminum cases like the betas. They'll include the buttons and the reference 510 connector.
  13. I think you'll find that LifePO4 batteries tend to be about 15-20% larger than the equivalent LiPo's. Their energy density (energy/volume) is lower.
  14. We are looking to fill several positions in the near future. If you qualify and are interested please contact us. Senior CNC Machinist Key Resposibilities: Designing, machining, and building fixtures for electrical and mechanical assembly. Doing setup and tooling for short and long run products. Operation of palletized and automated machining cells. Must possess: Programming experience Pluses: Fluency in HSMWorks, SolidCAM, or equivalent CAM software Robot and Automation experience Supervisory Experience Some tool and die experience Type of employment: First shift/full Time with benefits Base Pay: $30/hour plus benefits Automation Engineer Key Resposibilities: Design, oversee construction, construction, and programming of automated assembly cells and lines. Must possess: Minimum 5 years experience (10 years preferred) Experience with PLC and robot programming Experience with machine vision systems and computer programming Mechanical and electrical design experience Experience with automated material handling and automated assembly B.S.M.E., B.S.E.E., or equivalent Pluses: SolidWorks Experience CNC machining or SMC electrical assembly experience Type of Employment: Salary Pay Range: $80,000 to $120,000 per year dependent upon experience Electrical Assembly Techs Key Resposibilities: Soldering, electrical assembly, and mechanical assembly. Operation of automatic and semi-automatic machinery. Must Possess: Excellent vision and motorskills as all of the parts you'll be working with are small Basic computer proficiency Excellent attention to detail Pluses: Experience working in high production environments Type of Employment: Full time with benefits Pay Range: $14 to $17 dependent upon experience We are also looking for several entry level assemblers, who would like to learn the trade and grow with the company.
  15. here you go MI12832DOconnector.zip
  16. Here are the Solidworks files. DNA200Case.zip
  17. We should have a manual, interactive tutorial and EScribe link up in the next day or so.
  18. It was written in house.
