Brandon
Everything posted by Brandon
  1. We will put one together with an LED and post pics but probably won't be until next week.
  2. If you look below the fire button you will see 4 small solder pads. Attach a 100 ohm resistor between the 2 pads on the left above the screen-printed 'F'. Resistor link Above the fire button, near the board edge and slightly off to the right, you will see 2 identical small solder pads. Attach your LED there, cathode side toward the middle of the board. That will give you what you want.
  3. Let it charge up once fully and the meter will set itself or go to Device Monitor->Diagnostics->Set Charge Estimate to set the current charge level. You're not in any danger.
  4. Hmm, Opus uses the same screens everyone else uses. Even came out of the same batch we received. Are you certain the Nickel case isn't making it appear brighter?
  5. I spoke with Trent about your mod this morning. He assures me he'll personally take care of it quickly. Here is the contact page, either call or email https://www.hanamodz.com/index.php?main_page=contact_us
  6. Welcome Francisco!
  7. Yes, I'll admit they are more manly.
  8. The audible clicks would drive me nuts.
  9. Fuzzyje, if you go to tools->reboot device->hard reboot, does it brighten for a spell and then dim again or does it stay dimmed?
  10. John, can you reach that knife in my back? It's in there deep.
  11. How dare you!!
  12. When we have some for sale, they'll be here http://www.evolvapor.com/dna200.php
  13. Due to the new board dimensions and input power requirements, many of the vendors are having to totally redesign their mods. Remember, we had 3 generations of dimension-ally identical boards. Opus just happened to have a dual 18650 case that fit a lipo rather nicely, which allowed him to get to market sooner. I suspect you'll see quite a few production mods hitting the market in the next 2 weeks.
  14. @Adski, Love the Pip Boy graphic!!
  15. Miskol, the board is not available yet. We hope to have it available soon.
  16. John tested it on an HP stream 7 tablet and it worked fine. You can pick one up on Amazon for $70-$80 and it's quite portable.
  17. The Data sheet shows 3 possible orientations for the balance connector. If you are mounting using the through holes, the slot goes down (farther from the USB).
  18. Hi Steamer, Go here and submit a tech support ticket. We'll send you instructions for RMA.
  19. Jeff, I'll send you a PM with the shipping address. It sounds like a blown fuse but the question is what is causing it? John wants them sent directly to us for post mortem. We'll replace the board and ship it right back.
  20. Opus is not a daughter manufacturer of Evolv. The owner of Opus (Roger) used to do some contract assembly work for us when we were still manufacturing the Darwin. After we retired the Darwin he wanted to start his own mod company. I lent him the money to start the business and helped him incorporate. He paid me back in full, a year later and I ceased having any interest in Opus. Opus is fully owned by Roger and has no ties to me or Evolv.
  21. David, If you have a multi-meter, measure the total pack voltage and see if it matches the 4V reported in the device monitor.
  22. If the pack shipped with a cell out of balance, it will charge but it will likely charge very slowly. Get a reading of the 3 cells from the EScribe device monitor and post them here. We may need to walk you through a USB recovery charge.
  23. The firmware due this week has a battery analyzer which will generate and save an accurate discharge curve.
  24. Shogun, PM me with your address. We'll get a button out to you asap.
  25. A good connection to the main ground should be sufficient.
