LT Rogers
Everything posted by LT Rogers
  1. Okay so I have 2 different dna250 devices that use lipo packs. The batteries accidentally got drained down to zero percent. Now when I plug them in the led turns red, then green and off after that and the device doesn't charge. Can someone tell me what the led code represents? Also how do I fix this? Will the battery recovery in escribe fix this? The batteries are hard wired into the devices so I can't just pull them and charge externally. Thanks for your help!
  2. I think I may have been misunderstanding what you was telling me. If you meant did I remove the Carbon fiber -like sticker on the backside, yes I did and removed all screws. It's really just the 510 that has me lost. I think I'm going to have to use a cut off wheel and cut it out then just hope the hole on the top is a industry standard size hole. Out of the couple dozen L. V products that I've owned over the years not once did the 510 ever fail
  3. Have you disassembled any other Lost Vape devices? I have a few different ones here and they all pretty much have that same style of 510 with a weird locking nut so any recommendations on the type of tool I need to loosen it?
  4. I pulled off the back panel as you suggested and on this device there is no screws back there. Since the board sits in the front it does not have the holder like the other lost vape products it products where the screws are covered by the sticker as you had mentioned.. Do you know the best way to remove this 510. It's in such a tight spot
  5. You guys have the board actually actually mounted different than the effusion. Is it's mounted through the front with a front which screws into the fronthe frame and all screws you can access by removing the front button plate. Removing that backside panel you are Talking about I don't think would give me any more access than I already have
  6. I don't think I need to. I was already able to remove the board and everything, it is just the 510 Locking nut I do not know how to remove
  7. I just can't get the 510 off. Lol. I think I'm going to end up using a cutting wheel and chopping off the locking nut holding the 510 in. Unless anyone has batter ideas?
  8. I actually Have a stockpile of all different boards from the 40 up to the 250 in both color and non color. For a year or 2 straight I was surfing all of the groups on Facebook and reddit snatching up all the devices people had listed as broken which most of the time honestly the either had a dead lipo or a stuck button. So I have a pretty good stash of - of boards. The main issue I'm having is with the 510. Excuse the potato picture but the 510 I'm not exactly sure how to get out without tearing up the device . I'm sure if I can get this one out I can replace it with a different brand.
  9. I have a lost vape halycon that needs the board replaced and probably the 510. The board replacement is straight forward but as for the 510 does anyone know of a replacement I can source? The plastic board holder is in rough shape too but I can make it work hopefully. If anyone has disassembly pictures or tips I'd appreciate it
    Nice theme, I have tons of TRVP gear so this was perfect. I'd like to see replay added and a version for the 250C
  10. Are you running the international version or the U.S version of escribe?
  11. Looks interesting
  12. Yep, I had to use the international version to get it to work, but all seems fixed right now. Thanks Everyone!
  13. Then I'm Really Confused. I re-installed Escribe today and it's still on sp25
  14. Does this just update escribe or the device as well?
  15. Sorry for being stupid to the way a forum works, I see the post but don't know which is the newest version
  16. My light goes out. I don't have the issue on my device using the same themes. On his device I did as you suggested with the reset and the light doesn't go out. Now the light isn't bright but you can see it in a dark room. Joey's device came with the light on straight out of the box before it was hooked up to any computer or escribe for that matter. I'm at a total loss as of now.
  17. Does SomeOne Have A Link For SP27? I Did A Reboot And It Knocked Me Down To SP25, Now I Don't See Any Option To Get Back To SP26 Or SP27. Thanks For The Help In Advance! (This Was on A Dna75C Device ) *Device Monitor Says Version 1.1SP25.
  18. I helped Joeygregory install the theme. The light was on before I loaded the theme, I went into theme Designer and turned off the light but it still stays on. The Original theme is listed under my name, I Attached it here CARBON_W_TNSMASK.ecigtheme
    Bad Ass! Nice theme made for a facebook group. Alot of work and custom stuff!
  19. Version 1.1
    306 downloads
    Credit For Original Theme Goes To Shaun Wilkerson, He Tweaked JoeCockBill's Theme To Match Our Preferance. It's For The #TEAMNOSTEEP Group, Specifically For Jeff Jacobs's Lost Vape Paranormal, Can Be Used On The Therion 75C Just Fine.
