Everything posted by James
@mactavish: I just tested on MacOS Sierra 10.12. I got it working, and am making an update right now. -
@copyman: That's the same crash. Are you sure you downloaded it again and ran the new one? (Try clearing your browser cache.) I am testing it on MacOS Mojave (in a VM) right now and it is working. -
@copyman: I have updated the download with a fix to that bug. Redownload and reinstall and let me know if it now works for you. Thanks! -
I've posted up the Mac version of EScribe Suite, Service Pack 45: https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/#comment-939267
Oh interesting. @immelman: What permissions do you have for /home/(username)/.local/opt/evolv/escribe-suite? Is it owned by root, by any chance? (It should not be.)
It doesn't automatically launch after install. It should put itself into your launcher menu's "Other" category.
I've posted a new service pack, SP45, for EScribe Suite. It includes test firmware for DNA Color devices, with "Session Mode" and fixed "Temp Sensing Detect". Let me know if you run into any bugs with it! Enjoy https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=939267 -
@copyman: Found the bug. Thanks for your feedback! It is now fixed in SP45. -
@Magigamix: I will look into this. Thanks for your feedback! -
I've posted a newer installer up. Let me know how it works for you! Enjoy
I've posted a new service pack, SP44, for EScribe Suite. It includes test firmware for DNA Color devices. Let me know if you run into any bugs with it! Enjoy https://forum.evolvapor.com/topic/66731-early-firmware-and-escribe-suite/?do=findComment&comment=939267 -
EScribe Suite 2.0 SP45For US-based customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP45_US_ServicePack.exe For US-based customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP45_US.pkgFor international customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP45_INT_ServicePack.exe For international customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP45_INT.pkgFor customers using Linux, see the beta thread. Have a good weekend James --- DNA 75 Color, 100 Color, 250 Color --- This test firmware, SP55.1, adds a "Session Mode". When enabled, you don't have to hold the Fire button down. Instead, you press it to start firing, and press it again to stop firing. This is useful at low power settings (or with a temperature-sensing coil), especially with high thermal mass coils or e-liquids that need to warm slowly. You can enable Session Mode and customize the Session Time using EScribe Suite, or on the device if you have a compatible theme. For theme designers, the fields you need are "Atomizer -> Session Mode -> Enable" and "Atomizer -> Session Mode -> Time". Researchers should be aware that on-device trace recording only works for the first 64 seconds of a puff. This test firmware also fixes a problem with "Temp Sensing Detect". Previously, the device would not attempt to re-detect whether a coil was temperature sensing or not after disconnecting and reconnecting the coil. Now, it does. --- EScribe Suite --- Readded support for MacOS 10.12 "Sierra". Added support for MacOS 10.16 "Ventura". Minor bug fixes.
I'll have to give Mint 20 a try and see. FWIW, this gives you more information while connecting: udevadm control --log-priority=info To switch it back: udevadm control --log-priority=err
ttyACM is for the device's serial port. Hmm. Mine also restricts it to USB Vendor ID 268b, and adds tags (used by some newer distributions). How old is the OS on that one? Do you get any udev errors when connecting it? https://unix.stackexchange.com/questions/36251/in-which-log-should-i-check-for-udev-errors
Interesting. How is your 99 rules different from the 60 rules, then?
By any chance is that system missing /usr/bin/pkexec? (That and bash should be all that is needed for the 'grant permission' script, which doesn't appear to have copied the rules in your case.) (Alternatively, are there any permissions set on the system which would prevent a file from the user's temp directory being copied to /etc/udev.d ?)
What does it say if you send this command? getfacl /dev/hidraw2 Is there a file 60-dimension_engineering.rules in /etc/udev.d ?
What are the permissions on the hidraw device? On mine it's user root, group plugdev.
The crash was related to a condition in the theme. For some reason it had not been stored properly in the device memory.
What theme is your device running? Try this: https://downloads.evolvapor.com/SetupEScribe2_2022-04-26_INT_test2.run
@AmadVaper: See if this version still crashes for you: https://downloads.evolvapor.com/SetupEScribe2_2022-04-26_INT_test.run It's more recent, so if it does crash, I should be able to decode the crash more easily. Thanks! James
I've posted up SP 31 for EScribe Suite. Mostly minor bug fixes (though I did find one Linux-specific crash bug). It also includes a new firmware for DNA 75 Color.
EScribe Suite 2.0 SP31 For US-based customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP31_US_ServicePack.exe For US-based customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP31_US.pkg For international customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP31_INT_ServicePack.exe For international customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP31_INT.pkg For customers using Linux, see the beta thread. Merry Christmas James --- DNA 75 Color --- "Hide this profile" option, if you want to use less than 8 profiles.Highlighted fields now time out after a while. This is nice for themes with very visible selection colors. In the Display tab, "Indicator Light: Flash the battery level after firing" brings DNA Go-style battery level flash to DNA 75 Color. --- EScribe Suite --- Minor bug fixes.
EScribe Suite 2.0 SP30.5 For US-based customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP30_5_US_ServicePack.exe For US-based customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP30_5_US.pkg For international customers (Windows): https://downloads.evolvapor.com/SetupEScribe2_SP30_5_INT_ServicePack.exe For international customers (Mac): https://downloads.evolvapor.com/SetupEScribe2_SP30_5_INT.pkg For customers using Linux, see the beta thread. --- EScribe Suite --- Fixed a crash bug on Mac. On monochrome DNA devices, the locked Ohms is viewable again. (It being hidden was a bug.) Minor bug fixes.
