All Activity
This stream auto-updates
  1. Past hour
  2. Today
  3. Yesterday
  4. Last week
  5. I can confirm that I have gotten 5 replacements from Evolv
  6. Hi all,im buy and waiting to arrive my first 250c (therion v2 LVE)but cant wait for take my hand on theme and config ,im searching a good theme for install or mod,im take the theme BLYel Digital for testing editing theme and make twicks like theme changer (can change carbon background in 4 diferents colors on all screens not only lock ) and logo changer (added 3 logos )any idea for more tweaks,other good theme our other theme to mod like this ? "theme modified"
  7. Img of theme
  8. This its a simple carbon fiber theme whit not led Image added to theme theme:carbon.ecigcolors
  9. Version 1.0.0
    9 downloads
    this its a simple color scheme for 80c whit black and grey fonts and skuls image
  10. Try going to Tools -> Diagnostics -> Reboot Device -> Hard Reboot. Does this fix it? Thanks!
  11. Earlier
  12. Version 1.0.0
    11 downloads
    Original theme by Evolv color matched for the Sentinel by Cthulu.
  13. i looked over this thread, but the solution @use it with 0.4 ohm@ is not an option,
  14. Open an offical 'Help Desk' ticket and relate your needs. * That SP only adds the OXVA DNA device. Link in my signature line.
  15. Is there any possibility of SP67 appearing for Mac? Starting to feel like a second class citizen here..
  16. i tried on 10 cables, changing device, and reinstall software many times but still same error, i dont know what should i do or it can be fix by updating escribe or anything else. Im using escribe latest version for oxva
  17. Yesterday after i buy the oxva. I tried to change the wallpaper using Escribe, when first time i plug in, it can connect and works properly and i can change the wallpaper, after 3 times i plug, appears message "Cant Figure Out This Device Version", i tried to uninstall and reinstall again is not solve, plug in and unplug, and i can't reboot device soft and hard, but the escribe says is connected and detected, how to fix it or explain i want to change my wallpaper to default
  18. Do this and you'll see Puff time
  19. Hello ! I have the same problem on my aio, but on escribe in "Mod" > "Safety" I only have the Replay "Allow" "Restrict" thing, nothing about the max. Puff time, I changed it on the "Safety" page but nothing changed... Thank you in advance !🙂
  20. Version 1.0.0
    25 downloads
    雾化器自动检测阻值,不会显示新雾化器。 因为中文贴图过大所以制作功能有限。 竖版中文,删除过多无用选项。 修女精简版。 封绘大图就是电量或者主屏爱心就是电量。
  21. hello author / developer. Please provide oxva escribe software for Mac :)
      • 1
      • Like
  22. so six years later my boxer 100 is doing this exact thing. Did you ever figure it out?
  23. Version 1.0.0
    27 downloads
    Simple font switch for DNA80C specifically made for my Boson AIO. With original Boson logo, digital clock style fonts, black background, clean and simple.
  24. I too, would like this profile. I have an internal 21700 (non-removable) P45B in a custom made mod. The battery will only charge up to 4.14V (98%). Trying to get it to go up to 4.2V.
  25. Unfortunately, the original FullyMax one cannot be found There is the FullyMax one around, but without the 6-pin connector and even that is not easy to buy.
  26. Well, I didn't make it up, the 6-pin connector is what the DR200 is fitted with as standard. I could get a 900mAh battery that I found from eBay but it's not the original one and I don't know how reliable it can be, but anyway it has the original connector. I'd have to wait about a month to get it at home and I'd pay about 27€ While the 1400mAh one I could have it in 2 days because it's on sale with Prime on Amazon for 18€, but I'd have to transplant the connector removed from the old battery to that one.
  27. From your description you potentially have 2 different problems. Lines on your dimming screen and fire button no longer working. The screens are very delicate and are easy to damage if mishandled by you or the builder. The fire button is an external button (not the one on the board itself). It could be just a soldered wire that has come undone or the button itself, or lastly the board itself. You could dismantle the mod and push the on board button to see if it works, but I would not suggest that due to the delicate screens (but yours already appears on the way out) Due to the above it's hard to come to the conclusion that the board is defective. You should reach out to the place of purchase if you still have a warranty, or Jai's builder for service. Keep us informed on what you decide to do, and what they say.
  28. Hello everyone. Liebe I have a Jaio Mod Dna60c. Last night, I know, I had to change the 18650 (3%) because fine lines are appearing on the screen. I didn't think anything of it and changed the 18650. It is fully charged and I still have the problem with the lines or almost black screen. You can see the screen glowing very dimly. I connected it to the esrobe. Device Manager says the battery is full, but when I press the fire button the wattage display stays at 0. I opened the mod and checked the fire button. This works with the resistance meter. Question: is the chip defective? How could this happen? The mod did not get wet. Thank you for the help.
  1. Load more activity
