Material-ish Fire - DNA75c - DNA250c Optimized 2.0.0
   (14 reviews)
Notes:
  • You can press the fire button to exit out of a screen that doesn't have a back button.
  • LED colors styled to the theme.
  • When you change the material of a profile (eg. from Watts to SS316L) you won't have the appropriate toggles (eg. Temp Control, Replay)  activated right away. You need to back out of the Atomizer Profile screen, fire the mod and go back into the Atomizer Profile screen. This is an Evolv/Theme Designer issue.
  • If you have temp control enabled, you can switch positions of the power and temperature field on the main screen by enabling "Big Temp" in Menu -> Settings
  • In the Atomizer Profile screen you can adjust the Pre-heat temperature either via a Punch gauge or via a Temperature field. You can switch between them with the new toggle next to the Pre-heat label.
I made this version with the new DNA250c Paranormals in mind. I think it would look good on the darker ones especially. I'd love to see some handchecks if you're using it on a Paranormal!
What's New in Version 1.1.2   See changelog
  • You can now interchange the temperature and power field on the main screen. Go to Menu > Settings and enable "Big Temp"
  •  Resistance wasn't updating to show the current resistance as you fire. It's fixed now.
What's New in Version 1.1.1
  • Removed all instances of temp adjustment on replay profiles.
  • On replay profiles the middle right field on the main screen now shows puff time on replay profiles until you hit save.
What's New in Version 1.1.0
DNA75c now supports replay!
DNA75c now supports replay with the new international firmware 1.1 SP33.2 INT. As such I no longer need to maintain two separate versions of the theme. You can flash the same Material-ish Fire 1.1.0 theme file on both DNA250c and DNA75c.
You have to have 1.1 SP33.2 INT firmware flashed on your DNA75c device for this theme to work.
  • Tweaked how replay looks.
  • Resistance lock status icons have been changed once again. Resistance locking from the atomizer screen now functions similar to the lock icons in the Gauges theme. Sorry to have made so many changes to this.
  • Last puff and Live Puff screens now shows the puff counter.
  • Previously the main screen linked to the Live Puff screen. Now it links to the Last Puff screen.
omghax
Report ·
This is now my new default, from Material Dark. I was going to try and make my own but what's the point now! Thank you so much ❤️
Share this review
Mr.Ninno
Report ·
   0 of 2 members found this review helpful 0 / 2 members
This is missing some functions But It is Not bad.
I'm happy to take requests. What would you like to see added?
Share this review
Malpo69
Report ·
Great job, perfect for my VTbox 250c Black Red
Share this review
monstis
Report ·
Rocked this theme as soon as I first plugged my Paranormal in. Love it! So very functional. Suits my style of use perfectly.
I have tried others since but kept going back to it.  I have made some changes to the charging, main page and  coil change page.... nothing else.
The changes weren't needed as it was  perfect for me  to begin with. I just like to customize is all.
Keep it up!
Share this review
Fiark
Report ·
how to overwrite replay puff
Share this review
Ravn
Report ·
Brilliant theme! Looks good, informative, and easy to use.
Share this review
puma303
Report ·
I find this really interesting theme. However, I would like to ask if in temperature control it was possible to display the coil temperature and the watts used in this mode.
Share this review
Kirah
Report ·
Looks fantastic its my favorite theme by far only thing i would like more is a black / gray scale version of it
Share this review
Aether
Report ·
I like it! I'd definitely like more recolors available! But the template is super clean.
I just tweaked it a little to try and match, thanks for the hard work!
https://imgur.com/a/rlsEBTi
Share this review
cary@cpr-data.us
Report ·
Nice job !
Very clean, easy to find, with all the bells & whistles.
Thanks for sharing
Share this review
Tiago Afonso
Report ·
Great work and innovative design!
Share this review
rob cuisinier
Report ·
verry nice theme keep the good work thanks
                                               gr rob.
Share this review
Yorkyboy
Report ·
Great theme.  Very clear and some great design features.  Thanks for sharing your hard work :)
  • Thanks 2
Share this review
Vapin
Report ·
Love it Tim, you have another winner, thanks for the work and taking the time to create great themes. :thumb:
Share this review
