Notes:
- You can press the fire button to exit out of a screen that doesn't have a back button.
- LED colors styled to the theme.
- When you change the material of a profile (eg. from Watts to SS316L) you won't have the appropriate toggles (eg. Temp Control, Replay) activated right away. You need to back out of the Atomizer Profile screen, fire the mod and go back into the Atomizer Profile screen. This is an Evolv/Theme Designer issue.
- If you have temp control enabled, you can switch positions of the power and temperature field on the main screen by enabling "Big Temp" in Menu -> Settings
- In the Atomizer Profile screen you can adjust the Pre-heat temperature either via a Punch gauge or via a Temperature field. You can switch between them with the new toggle next to the Pre-heat label.
I made this version with the new DNA250c Paranormals in mind. I think it would look good on the darker ones especially. I'd love to see some handchecks if you're using it on a Paranormal!
What's New in Version 1.1.0 See changelog
DNA75c now supports replay!
DNA75c now supports replay with the new international firmware 1.1 SP33.2 INT. As such I no longer need to maintain two separate versions of the theme. You can flash the same Material-ish Fire 1.1.0 theme file on both DNA250c and DNA75c.
- Tweaked how replay looks.
- Resistance lock status icons have been changed once again. Resistance locking from the atomizer screen now functions similar to the lock icons in the Gauges theme. Sorry to have made so many changes to this.
- Last puff and Live Puff screens now shows the puff counter.
- Previously the main screen linked to the Live Puff screen. Now it links to the Last Puff screen.
With version 1.1.0:- Download
