About This File Description_for _translation.txt Edited November 10, 2021 by CMK aka gwyar What's New in Version 4.0.3 See changelog Released May 2, 2020 4.0.3: Spelling error BATTERIE => BATTERY fixed 4.0.2: in the event of a final change, the status window on the mainscreen is lost .... ok, shit happens - it's back again 4.0.1: Resolution of the manual resistance setting refined to 0.001 With version 4.0.3: Download 11/10/2021 04:34 AM 11/10/2021 04:32 AM November 10, 2021 11/10/2021 01:02 AM November 10, 2021 11/07/2021 02:56 PM November 7, 2021 V5.4.5 June 19, 2021 V5.3.2 June 15, 2021 V5.3.1 June 14, 2021 V5.3.1 June 14, 2021 V5.3 June 13, 2021 V5.2 June 11, 2021 V5.1 May 25, 2021 V5.1 May 25, 2021 4.3.5 March 18, 2021 4.3.2 July 16, 2020 4.3.2 May 21, 2020 4.3 May 16, 2020 4.3 May 16, 2020 4.3 May 16, 2020 4.2 May 13, 2020 4.1 May 8, 2020 4.0.6 May 4, 2020 4.0.5 May 3, 2020 4.0.3 May 2, 2020 4.0.3 May 2, 2020 4.0.3 April 29, 2020 4.0.2 April 28, 2020 4.0.1 April 27, 2020 4 April 27, 2020 4 April 27, 2020
zark 107 April 27, 2020 1 of 1 member found this review helpful 1 / 1 member Report Безусловно, очень серьёзная и грамотная разработка. Ставлю наивысшую оценку, но все же, мне кажется, что необходимо увеличить разрядность сопротивления +/- 0.001 это слишком грубо для корректировки вручную ( ИМХО). В целом стиль, функциональность и удобство оценка отлично! Response from the author: I did it 😉
Gavnaf 16 July 19, 2020 0 of 1 member found this review helpful 0 / 1 member Report The settings that I put in one screen, to which you go by pressing one button, you made on three different unreadable screens, which you still need to get to. Very confusing menu, strange choice of colors, small print. I am preparing a modified version of "Argus 2.0" where the same settings will be placed in one tab of the main screen. In my themes, I always try to make the interface as friendly and fast as possible, but you confused everything so that you yourself had to draw labyrinths in the description. Response from the author: It is interesting to hear your opinion. Are you criticizing based on the screenshot (s) or have you installed the theme? I mean, the operation is quite intuitive once the principle is understood. Incidentally, I do not understand the criticism of the font size at all, you use smaller font yourself ... The choice of color and font are based as closely as possible on the LCARS specifications. Maybe you should google "LCARS" to understand the graphics - then you will also recognize the effort behind this theme. "In my themes, I always try to make the interface as friendly and fast as possible, but you confused everything so that you yourself had to draw labyrinths in the description." You should do the work to completely depict your own theme as a diagram - you would be surprised that it looks insignificantly less complex. In short - I think you just didn't understand my theme.
