* NEW preheat feature in watts mode for kanthal / non temp control coils *
Note: For this feature to work correctly you will need to upload this theme using EScribe Suite 2.0 SP6 (or later) to a device with international firmware 1.1 SP26 (or later). For more information please see here: Early Firmware and Escribe Suite and here: Why international only .
I started with JCBs therion theme and added elements I liked from various other themes, I've also added a few extra screens to fit in all those settings.
US version: Date format m.d.yy and spelling e.g. atomizer
UK/AU version: Date format d.m.yy and spelling e.g. atomiser
Different backgrounds have different colour schemes, e.g. the mossy green version uses green headings and green highlights etc.
Dark Twilight Light Rays Cloudy Colour Deep Blue Diagonal Blue Mossy Green Ocean
Features / how to use:
~Main Screen~
- The two icons toward the middle if the screen are selectable, the left one takes you to Device Monitor and the right takes you to Puff Info.
The value below the left icon displays the achieved wattage during the last puff, this is mostly useful for temp control but it can also be useful for battery diagnostic.
The value below the right icon display last puff time. - Selecting the coil material (when in temp control) will take you directly to Atomiser Settings.
- The values at the very bottom are board temperature and battery voltage, useful for quick diagnosis.
etc.
3 = Screen turns off
2 = Very dim
1 = Dim
-Indicator light:
Fade in/out red = charging
Green = charge complete
Blue/purple = firing
Enjoy!
P.S Thank you to all the theme creators whose elements I've ruthlessly and mercilessly pinched. Happy to remove them if it is an issue, just let me know ![]()
Edited by jakeT
What's New in Version 1.0.6 See changelog
Updated to include preheat in watts mode, a feature introduced in SP26. It is now possible to set a 'boost' power for non temp control materials for up to 1 second. When Watts mode is selected Preheat Temperature on the Atomiser screen is replaced with Preheat Time.
To use preheat in watts mode you must update to SP26. Using a preheat power of up to 100W is now possible but requires some configuration in Escribe. Refer to official documentation to effect these changes but please have a decent knowledge of battery safety before doing so.
With version 1.0.6:- Download
