	* NEW preheat feature in watts mode for kanthal / non temp control coils *
	Note: For this feature to work correctly you will need to upload this theme using EScribe Suite 2.0 SP6 (or later) to a device with international firmware 1.1 SP26 (or later). For more information please see here: Early Firmware and Escribe Suite and here: Why international only .
	I started with JCBs therion theme and added elements I liked from various other themes, I've also added a few extra screens to fit in all those settings.
	US version: Date format m.d.yy and spelling e.g. atomizer
	UK/AU version: Date format d.m.yy and spelling e.g. atomiser
Different backgrounds have different colour schemes, e.g. the mossy green version uses green headings and green highlights etc.
Dark Twilight Light Rays Cloudy Colour Deep Blue Diagonal Blue Mossy Green Ocean
Features / how to use:
~Main Screen~
- The two icons toward the middle if the screen are selectable, the left one takes you to Device Monitor and the right takes you to Puff Info.
		 The value below the left icon displays the achieved wattage during the last puff, this is mostly useful for temp control but it can also be useful for battery diagnostic.
The value below the right icon display last puff time. - Selecting the coil material (when in temp control) will take you directly to Atomiser Settings.
 - The values at the very bottom are board temperature and battery voltage, useful for quick diagnosis.
	  etc.
	  3 = Screen turns off
	  2 = Very dim
	  1 = Dim
	-Indicator light:
	  Fade in/out red = charging
	  Green = charge complete
	  Blue/purple = firing
Enjoy!
	P.S Thank you to all the theme creators whose elements I've ruthlessly and mercilessly pinched. Happy to remove them if it is an issue, just let me know ![]()
Edited by jakeT
 With version 1.0.3:
