Therion 75C - 8 Background Options - UK/AU & US versions 1.0.6
   (12 reviews)
* NEW preheat feature in watts mode for kanthal / non temp control coils *
Note: For this feature to work correctly you will need to upload this theme using EScribe Suite 2.0 SP6 (or later) to a device with international firmware 1.1 SP26 (or later). For more information please see here: Early Firmware and Escribe Suite and here: Why international only .
I started with JCBs therion theme and added elements I liked from various other themes, I've also added a few extra screens to fit in all those settings.
US version: Date format m.d.yy and spelling e.g. atomizer
UK/AU version: Date format d.m.yy and spelling e.g. atomiser
Different backgrounds have different colour schemes, e.g. the mossy green version uses green headings and green highlights etc.
  Dark Twilight            Light Rays                Cloudy                   Colour                  Deep Blue           Diagonal Blue         Mossy Green              Ocean
 598e73959e09d_CloudyDemonBlood.png.47afe8e6a2a3a2497cf61a2e49f41a73.png         598e739738b5d_CloudyLightRays.png.cabc865939f11072a3554d0f6644651d.png         598e7397c85cd_CloudyRainbow.png.30db759aba3d0e7aa8268e9782066b81.png         Multicolour.png.54d487dce699acb6bfc2a9022ac33819.png         59855a66c0104_DeepBlue.png.bb88b7fae1ecf338c721db191f9d52f3.png         59855a838c68e_DiagonalBlue.png.4b85bac102b93f822af7776239ae3448.png         599e27e1adfa9_CloudyGreen.png.bbce1bbec3e1ff918f67419c278a1c16.png         599e27e377f39_CloudyWater.png.90809669d0c6dea68b4a1a0557c02649.png
Features / how to use:
~Main Screen~
  • The two icons toward the middle if the screen are selectable, the left one takes you to Device Monitor and the right takes you to Puff Info.
  •  The value below the left icon displays the achieved wattage during the last puff, this is mostly useful for temp control but it can also be useful for battery diagnostic.
     The value below the right icon display last puff time.
  •  Selecting the coil material (when in temp control) will take you directly to Atomiser Settings.
  •  The values at the very bottom are board temperature and battery voltage, useful for quick diagnosis.
  etc.
-Most screens feature a 'Back' or 'Exit' button or a combination of both. 'Back' will take you back to the screen you came from, e.g. if you go to Atomiser Settings from the Settings Menu the back button will take you back to the Settings Menu. If you go to Atomiser Settings by selecting the coil material on the Main Screen, the Back button will take you back to the Main Screen. In all cases the Exit button will take you directly to the Main Screen.
-Black background on the Device Monitor, Diagnostic and Device Info screens to make the text easier to see and read.
-Screens you can fire from: Main Screen (obviously), Atomiser Settings, Device Monitor and Diagnostic. Pressing the fire button on any other screen will give the same result as selecting 'Back'. e.g. if you are on the Display Settings screen you can press the fire button twice to go back to the Main Screen- pressing once goes back to the Settings Menu and another press takes you back to the Main Screen.
-Time & Date and Lock Settings are accessible from the System Settings screen.
  3 = Screen turns off
  2 = Very dim
  1 = Dim
-Indicator light:
  Fade in/out red = charging
  Green = charge complete
  Blue/purple = firing
Enjoy!
P.S Thank you to all the theme creators whose elements I've ruthlessly and mercilessly pinched. Happy to remove them if it is an issue, just let me know :)
Deep Blue.pngDiagonal Blue.pngMulticolour.pngCloudy Demon Blood.pngCloudy Light Rays.pngCloudy Rainbow.pngCloudy Green.pngCloudy Water.png
Edited by jakeT
  • Like 5
Joe Comanche
A great lovely serious looking theme. Nothing cartoonish about it. Would very much appreciate REPLAY mode added.
Andy72
Nice theme that I'm using on my Mirage 75c, however preheat function can be turned on or off only,  it cannot be increased between 0 and 11 as in other themes, plus there is no replay,  unfortunately making this a pointless theme if one wants to use two major features of the Mirage!
jakeT
Hi all, I’m an ex-vaper now and haven’t been maintaining this theme for some time!
If anybody wants to take over and update it please feel free to do so. If there’s anything you need, or if you want access to my account to post updates please let me know. You can contact me at jakejunk1@icloud.com
Cheers!
s3r
Best theme available, with the new replay function this got even more clear as no other is as sophisticated.
If Replay could be added it would be greatly appreciated!
Ectogenesis
Really like the look and features of this theme. One little thing I thought was great, adding the exit option on some screens, very useful :ok_hand:
Only issue I found was when the internal temp hit triple digits, it would shift the F down and cut off the numbers. Easy enough to fix just shifting that field to the right, or changing size to small.
Thanks!
rob cuisinier
verry nice jake T i like it thanks :)
                                             mvg rob :)
