You only need to post once. As right now you have three posts the same. And every time you fire the mod, the charge current drops back to 0 amps. And you are probably checking by pressing the fire button to check the screen's diagnostics. If the screen goes dark, use up, down, or select buttons instead. These buttons will light up the screen again at least an hour from the last fire button press. And you will see the charging start increasing up to the maximum.
Yes like Reddit. We covered a lot there that people here doesn't know about. Like your 10 foot cable. Can you post a screenshot of EScribe's Device Manager with it connected? As I like to see more than just the current.
Ah! Yes cell 1 is low while cells 2 and 3 are fully charged. It's in balance charging mode which it is only charging at 17mA. It will take days for it to bring up cell 1 to full charge. Once they are all balanced, this problem will disappear. It would be far faster right now to charge cell 1 in a single cell charger. Or you can wait until the DNA250C board finally balances them. You can still vape it while it is charging.
Edited by BillW50
  • Like 2
Expand
Looks like you were right thank you so much!
  • Like 2
