raberone Posted May 12, 2022 Report Share Posted May 12, 2022 (edited) Hi all! I'm having troubles using this mod in TC mode with RBAs: most of the time it says "Off". What can I do? It's awful that a 180$ mod can't what it should do. Edited May 12, 2022 by raberone Link to comment Share on other sites More sharing options...
BillW50 Posted May 12, 2022 Report Share Posted May 12, 2022 A DNA will kick out of TC if the wire type selected is wrong or you are using a non-TC wire. So what type of wire or coil head or you using? 2 Link to comment Share on other sites More sharing options...
raberone Posted May 13, 2022 Author Report Share Posted May 13, 2022 11 ore fa, BillW50 ha scritto: A DNA will kick out of TC if the wire type selected is wrong or you are using a non-TC wire. So what type of wire or coil head or you using? Hi! I’m using NiFe48 or 316L. I make simple coil with 5/6 spires with 2/2.5 diameter. Can be the Rba the problem? Is the Rubik rba and it has a lot of pieces Link to comment Share on other sites More sharing options...
Wayneo Posted May 13, 2022 Report Share Posted May 13, 2022 NiFe rears its ugly head again. Can you post a link where you bought this wire AND a screenshot of the NiFe Material Profile, like below. 1 Link to comment Share on other sites More sharing options...
raberone Posted May 13, 2022 Author Report Share Posted May 13, 2022 This is the wire https://www.zivipf.com/epages/63862298.sf/de_DE/?ObjectPath=/Shops/63862298/Products/NiFe48-0.32/SubProducts/NF48-0.32-10m Link to comment Share on other sites More sharing options...
Wayneo Posted May 13, 2022 Report Share Posted May 13, 2022 Thank you. So taken from zivipf; Alloy components: Ni 52%, Fe rest Temperature coefficient: 400 Well you do have the correct material file. so that's good. My 'ugly head' comment refers to Ziv using the '48' to identify the Iron content whereas steam-engine uses '52' to identify the Nickel content. Using escribe with your mod plugged in can you go to your SS316L and NiFe profile and make sure or change so that the temperature box under settings is chosen. (same thing as making sure the 'Off' is NOT highlighted) and let me which material had the 'Off' highlighted. Make sure to Upload settings to mod whenever you make ANY changes in escribe. Another way your mod could have got to 'Off' is on page 4 of the datasheet. Here's a snippet. 'The maximum temperature is adjustable between 200° Fahrenheit and 600° Fahrenheit. To disable the temperature protection entirely, adjust the limit up to 600 degrees, then press the UP button one additional time. The temperature limit will read OFF.' Here's where you can download the complete datasheet 'https://downloads.evolvapor.com/dna60.pdf'Edit: While you're in there (Material for NiFe52 you might want to change the 'On-Screen Name' from 'Ni' to 'NiFe or NiFe48' <- something no other mods can do 3 Link to comment Share on other sites More sharing options...
raberone Posted May 13, 2022 Author Report Share Posted May 13, 2022 Doesn't work either. Can it be the RBA? Link to comment Share on other sites More sharing options...
BillW50 Posted May 13, 2022 Report Share Posted May 13, 2022 Yes it can be. Since some attys are not stable (resistance-wise) enough for TC. PBusardo mentioned that the Kayfun mentions this in its own manual. 1 Link to comment Share on other sites More sharing options...
raberone Posted May 13, 2022 Author Report Share Posted May 13, 2022 So I'm gonna enjoy it in variwatt mode. A little sad and angry, this RBA costs 120 euros 😅 Link to comment Share on other sites More sharing options...
BillW50 Posted May 13, 2022 Report Share Posted May 13, 2022 Yes they are expensive. You could recheck the tightness of the screws and that might help. 1 Link to comment Share on other sites More sharing options...
raberone Posted May 13, 2022 Author Report Share Posted May 13, 2022 Yes, I will try. Thanks to you and @Wayneo 1 Link to comment Share on other sites More sharing options...
Wayneo Posted May 13, 2022 Report Share Posted May 13, 2022 I would not give up so easily raberbone. TC works easier with a spaced coil or you really gotta make sure there are no hotspots with a contact coil. At the bottom of the Profile page is Atomizer Analyzer, and with your mod plugged in it should show very small fluctuations, or a small rise then dropping (rinse and repeat). Then using Device Monitor (while taking a puff) with Power, Power set, cold ohms, live ohms checked/enabled we/you can monitor exactly what's going on. Screenshots appreciated. 1 Link to comment Share on other sites More sharing options...
raberone Posted May 14, 2022 Author Report Share Posted May 14, 2022 Il 13/5/2022 in 18:31 , Wayneo ha scritto: I would not give up so easily raberbone. TC works easier with a spaced coil or you really gotta make sure there are no hotspots with a contact coil. At the bottom of the Profile page is Atomizer Analyzer, and with your mod plugged in it should show very small fluctuations, or a small rise then dropping (rinse and repeat). Then using Device Monitor (while taking a puff) with Power, Power set, cold ohms, live ohms checked/enabled we/you can monitor exactly what's going on. Screenshots appreciated. Thank you @Wayneo. Unfortunately I can't test the box until Monday. Will update you on Monday morning and test the box. 1 Link to comment Share on other sites More sharing options...
raberone Posted May 16, 2022 Author Report Share Posted May 16, 2022 Hi @Wayneo! So, I did the test and the Ohm's values show small rises of 0,001 but the value doesn't stabilize. And then I will attach the screenshot of the Device Monitor. Link to comment Share on other sites More sharing options...
raberone Posted May 16, 2022 Author Report Share Posted May 16, 2022 This is the same test done with a different box. So, is it the box that doesn't work? Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 16, 2022 Report Share Posted May 16, 2022 By "box", do you mean Boro box? 1 Link to comment Share on other sites More sharing options...
raberone Posted May 16, 2022 Author Report Share Posted May 16, 2022 1 minuto fa, dwcraig1 ha scritto: By "box", do you mean Boro box? Yes, it's a Dovpo Abyss Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 16, 2022 Report Share Posted May 16, 2022 Is it the same RBA in the different box? Link to comment Share on other sites More sharing options...
raberone Posted May 16, 2022 Author Report Share Posted May 16, 2022 1 minuto fa, dwcraig1 ha scritto: Is it the same RBA in the different box? Oh no, sorry! I didn't understand. The first screenshot is from the AIO, the second is from a regular DNA 75c box. Link to comment Share on other sites More sharing options...
Wayneo Posted May 16, 2022 Report Share Posted May 16, 2022 For both tests was it the same Rubik rba with the same coil? AND did the Abyss switch to OFF? Link to comment Share on other sites More sharing options...
raberone Posted May 16, 2022 Author Report Share Posted May 16, 2022 3 minuti fa, Wayneo ha scritto: For both tests was it the same Rubik rba with the same coil? Yes Link to comment Share on other sites More sharing options...
Wayneo Posted May 16, 2022 Report Share Posted May 16, 2022 Wow! Even the Ω's are drastically different. We know your Rubrik works fine in the 75C. I think it has to be down to the connections on the Abyss. That small 0,001Ω fluctuation with Atomizer Analyzer is normal. Do you have another RBA that works in TC on the abyss? @BillW50 dont't you have an Abyss, and does yours work in TC? Link to comment Share on other sites More sharing options...
BillW50 Posted May 16, 2022 Report Share Posted May 16, 2022 38 minutes ago, Wayneo said: @BillW50 dont't you have an Abyss, and does yours work in TC? Yes, I have four of them with two still sealed in their boxes. One is currently using the Abyss EUC bridge with an EUC SS316L 0.5Ω coil head. Yes the TC is working just fine here. Link to comment Share on other sites More sharing options...
raberone Posted May 16, 2022 Author Report Share Posted May 16, 2022 I tried to change the screws on the deck and this is the result: 1 Link to comment Share on other sites More sharing options...
BillW50 Posted May 16, 2022 Report Share Posted May 16, 2022 The wattage is set on only 16 watts. Resulting in temperatures around 130°C (245°F). Why is it set so low? Link to comment Share on other sites More sharing options...
