vape vape Posted May 26, 2021 Report Share Posted May 26, 2021 For the mod resistance field in escriae, do I just enter the number after subtracting the internal resistance of the mod? What are the settings here? Link to comment Share on other sites More sharing options...
Wayneo Posted May 26, 2021 Report Share Posted May 26, 2021 What numbers are there right now? and why do you want to change it? To answer your question directly, no. It's not difficult, or complicated, but if you don't understand what you're doing then you probably should not. One would normally set the field to zero, then measure, set it to that or a slightly more conservative value. 2 Link to comment Share on other sites More sharing options...
vape vape Posted May 26, 2021 Author Report Share Posted May 26, 2021 My billet box shows a higher resistance than other DNAmods. For example, other DNAmods have a resistance of 0.7Ω. With the billet box, the resistance is 0.77Ω, which is 0.07Ω higher. I want to compensate for this 0.07. I only use power mode. Link to comment Share on other sites More sharing options...
Wayneo Posted May 26, 2021 Report Share Posted May 26, 2021 On 5/26/2021 at 4:19 PM, Wayneo said: What numbers are there right now? Expand Link to comment Share on other sites More sharing options...
vape vape Posted May 27, 2021 Author Report Share Posted May 27, 2021 OAM reader 0.7Ω Other 3 DNA boards mod 0.72Ω Billet box 0.79Ω Link to comment Share on other sites More sharing options...
Wayneo Posted May 27, 2021 Report Share Posted May 27, 2021 On 5/26/2021 at 1:49 PM, vape vape said: For the mod resistance field in escriae, Expand Buddy, we are talking the mod resistance field. The thing you want to change. What is in there right now? Or, sure, you can do that if you want. Here's a video showing how. https://youtu.be/S8f6WtY-f70 Or set it at .006 and work your way up slowly. After changing the setting, always 'upload to mod'. 1 Link to comment Share on other sites More sharing options...
vape vape Posted May 27, 2021 Author Report Share Posted May 27, 2021 I'm sorry. I don't understand. What is this mod resistance item for? Link to comment Share on other sites More sharing options...
Wayneo Posted May 27, 2021 Report Share Posted May 27, 2021 There are several resistances in series that make up the load before it reaches your coil measurement. Every solder and connection point. By properly measuring this 'mod resistance' and setting it, you are then seeing only the measurement of the coil. I guess your other 2 boards were properly done. So now you want all 3 to be the same, but you don't/won't/can't actually measure it on this board. So you can follow that video, or fudge your way to be the same. Follow my last post. 1 1 Link to comment Share on other sites More sharing options...
vape vape Posted May 27, 2021 Author Report Share Posted May 27, 2021 Thank you very much! The resistance of the billet box adapter is high. Is it dangerous to roughly adjust 0.02 with that in mind? Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 27, 2021 Report Share Posted May 27, 2021 For what it's worth. The mod resistance on my two SXK Billet boxes are set to 0.011 ohms. They were measured using my shorting tool. One came out to 0.010 and the other at 0.011 so I set them both at 0.011 ohms. Contact area need to be clean 1st. 1 1 Link to comment Share on other sites More sharing options...
vape vape Posted May 27, 2021 Author Report Share Posted May 27, 2021 Thank you! Does your billet box also have a jump in resistance? Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 27, 2021 Report Share Posted May 27, 2021 Only when using TC capable wire. As it should. But with kanthal or nicrome the resistance should be stable. 1 Link to comment Share on other sites More sharing options...
dwcraig1 Posted May 27, 2021 Report Share Posted May 27, 2021 A lot of good info here: https://www.e-cigarette-forum.com/threads/sxk-billet-box.898599/ By using Google Chrome for a browser you can get good translation by right clicking the post and select "translate" 1 Link to comment Share on other sites More sharing options...
vape vape Posted May 27, 2021 Author Report Share Posted May 27, 2021 I'm looking! The billet box is 0.07Ω more expensive than other DNA mods when built with Kanthal.😭 Link to comment Share on other sites More sharing options...
TonyB Posted August 1, 2021 Report Share Posted August 1, 2021 On 5/27/2021 at 12:19 AM, Wayneo said: Or, sure, you can do that if you want. Here's a video showing how. https://youtu.be/S8f6WtY-f70 Where is the button to check Mod Resistance? Escribe has changed and I don't see it now when connected to a DNA60 mod. I have a copper shorting pin but cannot see the Electrical Section as shown in the video in Escribe anymore. Expand Link to comment Share on other sites More sharing options...
BillW50 Posted August 1, 2021 Report Share Posted August 1, 2021 (edited) On 8/1/2021 at 6:09 AM, TonyB said: Where is the button to check Mod Resistance? Escribe has changed and I don't see it now when connected to a DNA60 mod. I have a copper shorting pin but cannot see the Electrical Section as shown in the video in Escribe anymore. Expand I always used the Atomizer Analyzer. Made sure you set the internal resistance to 0 ohm first. I used the manufacture's interface. Mod -> Electrical Edited August 1, 2021 by BillW50 1 Link to comment Share on other sites More sharing options...
