Beligal Posted March 24, 2021 Report Posted March 24, 2021 Can anyone help me? I just bought a Thelema 250c, but it doesn't recognize any atomizer's Ohms. The box says "Check atomizer" and in Escribe it says "Failed to measure coil Ohms."; Ohms on the box stay at 0.00. Is it a known issue?
dwcraig1 Posted March 24, 2021 Report Posted March 24, 2021 Have you tried other atomizers? Some 510's on atomizers are on the short side as there is no standard for them. Does the 510's positive pin appear farther down than usual? 2
Beligal Posted March 24, 2021 Author Report Posted March 24, 2021 47 minuti fa, dwcraig1 ha scritto: Have you tried other atomizers? Some 510's on atomizers are on the short side as there is no standard for them. Does the 510's positive pin appear farther down than usual? Thanks for your reply. I did try a total of 3 atomizer, but none of them are being recognized by the Thelema. I tried the Geekvape Zeus (subohm), the Zlide and the SMOK TFV12 Prince. All the mentioned atomizers work on my SERIES B DNA75 flawlessly, so I don't think it is a problem with the atomizers. As for the 510 it doesn't appear farther down than usual, actually it kind of looks a bit taller than my other mods, but I may be wrong. The only thing that may stand out is the fact that the pin is a bit off centered.
Wayneo Posted March 24, 2021 Report Posted March 24, 2021 IMHO, If this is new, I'd return it to place of purchase. It would be DOA (Dead on Arrival)
zark Posted March 25, 2021 Report Posted March 25, 2021 (edited) Можно взять кусок проволоки длиной 10 сантиметров из кантала, нежавейки или иного материала для вейпинга и попробовать соединить центральный пин "+" с корпусом "-". При подключении к escribe будут какие либо показания сопротивления, если нет то обрыв проводки гнезда атомайзера Edited March 25, 2021 by zark
