eaknazareth Posted February 10, 2021 Report Posted February 10, 2021 How can fix error.? EEPROM programming failed Adress 0x500000 had the value 0 instead of the expected 255. Please help me fix this. Thank you.
Wayneo Posted February 10, 2021 Report Posted February 10, 2021 What were you doing beforehand that made you want to upload to the mod? Have you connected to this mod before and uploaded or upgraded the firmware?
eaknazareth Posted February 10, 2021 Author Report Posted February 10, 2021 Up fw and changed the theme. I don't have a back-up origins. The screen has only text, no picture, thank you for your help.🙏
eaknazareth Posted February 10, 2021 Author Report Posted February 10, 2021 9 minutes ago, Wayneo said: What were you doing beforehand that made you want to upload to the mod? I want to put the punch menu into the mod so I upgrade
Wayneo Posted February 10, 2021 Report Posted February 10, 2021 Under the 'Help' menu, down at the bottom, the mod has been creating backups for you. See if you can restore to a time before you attempted your changes.
eaknazareth Posted February 10, 2021 Author Report Posted February 10, 2021 29 minutes ago, Wayneo said: Under the 'Help' menu, down at the bottom, the mod has been creating backups for you. See if you can restore to a time before you attempted your changes. I tried to do it in the backup menu and I didn't get through the error. thank you Wayneo🙏
Wayneo Posted February 10, 2021 Report Posted February 10, 2021 Great news. Now go make your changes one at a time, and after each change do an upload to mod. Although you can make many changes at a time, something is wrong. When you find the offending change, let us know. Personally, I'd do them in this order. Escribe/Firmware then mod/materials, then theme. 👍
eaknazareth Posted February 10, 2021 Author Report Posted February 10, 2021 14 minutes ago, Wayneo said: Great news. Now go make your changes one at a time, and after each change do an upload to mod. Although you can make many changes at a time, something is wrong. When you find the offending change, let us know. Personally, I'd do them in this order. Escribe/Firmware then mod/materials, then theme. 👍 Wayneo Thank you so much. 🙏Can you suggest Escribe/Firmware version get work this mod.?
Wayneo Posted February 10, 2021 Report Posted February 10, 2021 Just install SP19 (link in my sig) and then the most current for your mod. Edit: 'Punch' is a term used for both TC and non TC material (wire) For TC it's "how much" to preheat before quitting preheat parameters. For non-TC it's "how much" to Boost (increase) the wattage before dropping back to the set watts
eaknazareth Posted February 10, 2021 Author Report Posted February 10, 2021 13 minutes ago, Wayneo said: Just install SP19 (link in my sig) and then the most current for your mod. I install this link here http://www.evolvapor.com/software/SetupES.exe it completed continue this program EScribe Suite 2.0 SP19 inter Failed EEPROM 😭 my headache
eaknazareth Posted February 10, 2021 Author Report Posted February 10, 2021 Wayneo Thank you very much. I would like to sleep first.🙏
Wayneo Posted February 10, 2021 Report Posted February 10, 2021 27 minutes ago, eaknazareth said: I install this link here http://www.evolvapor.com/software/SetupES.exe it completed At this point I have NO CLUE what version(s) of escribe you have installed. Delete all copies drom your PC so you can start fresh. That was not for color mods Download and install the link below. https://downloads.evolvapor.com/SetupEScribe2_SP19_INT_ServicePack.exe Make sure to open the proper folder for your mod board type.
eaknazareth Posted February 11, 2021 Author Report Posted February 11, 2021 7 hours ago, Wayneo said: At this point I have NO CLUE what version(s) of escribe you have installed. Delete all copies drom your PC so you can start fresh. That was not for color mods Download and install the link below. https://downloads.evolvapor.com/SetupEScribe2_SP19_INT_ServicePack.exe Make sure to open the proper folder for your mod board type. Hello. I can wake up. I just try to delete them all. Start over Thank you for your advice.
eaknazareth Posted February 11, 2021 Author Report Posted February 11, 2021 The same setup 1 setup 2 Not pass error EEPROM Is there a way to clear the mod? Press Restore Defaults not passed. 😰
dwcraig1 Posted February 11, 2021 Report Posted February 11, 2021 Are you able to try using a different data cable?
eaknazareth Posted February 11, 2021 Author Report Posted February 11, 2021 2 minutes ago, dwcraig1 said: Are you able to try using a different data cable? Hello, I have replaced the cable as before, this cable can be sent from the mod into the program.
eaknazareth Posted February 11, 2021 Author Report Posted February 11, 2021 18 minutes ago, dwcraig1 said: Are you able to try using a different data cable? Can connect, but when uploading mod error, fetch data from mod to Computer can Change the cable to 3 lines, does not pass😭 Thank dwcraig1🙏
eaknazareth Posted February 11, 2021 Author Report Posted February 11, 2021 I don't know how to go next step😅
eaknazareth Posted February 11, 2021 Author Report Posted February 11, 2021 The firmware in the mod seems to have a problem, but I don't know how to clear it. Please teach me.
dwcraig1 Posted February 11, 2021 Report Posted February 11, 2021 That seems to be the latest firmware for a DNA75 C Edited
eaknazareth Posted February 11, 2021 Author Report Posted February 11, 2021 2 minutes ago, dwcraig1 said: That seems to be the latest firmware for a DNA250 C 😱 Can you tell me? I'm all confused and can't go back to the factory. Thank dwcraig1🙏😭
dwcraig1 Posted February 11, 2021 Report Posted February 11, 2021 Have you tried flashing it back to earlier firmware?
dwcraig1 Posted February 11, 2021 Report Posted February 11, 2021 I edited my post about it being the latest firmware for DNA250C, it is the latest firmware for DNA75C instead, my mistake
eaknazareth Posted February 11, 2021 Author Report Posted February 11, 2021 2 minutes ago, dwcraig1 said: How many batteries does it use? Using one piece of 18650 battery, tried to upgrade and got error.
