Hello all,
Just run into my first problem with my Drone 250c.
I'm trying to vape a series(ish) build, dual 3.5mm coils ohming out about 0.38ohm in my Centurion atty.
I can select whatever wattage I want no problems, but under the main wattage selection I have a actual watts display and can see that it will not go above 110watts.
I've tried 2 different sets of good batteries (HG2s and 30Qs) but still got the same problem.
Is there some kind of voltage limit to these mods or something? I can see in the info that at 110w its 6.48v.
Thanks for any help you can give.
Edited by Monkspeed
added tags
What you have there is the limit of the cells. The output is never going to be higher than the battery voltage (under load). You have a couple of choices, build closer to .2 ohms. The other choice would be using 30 amp CDC cells like Samsung 20S. these would get you up around 135 watts on a charged set of 30 amp cells.
( You are really pushing those HG2s and 30Qs too hard)
It's OK, I'll lower ohms (take a wrap or two off), bit obvious really, can't take voltage higher than what you put in. I should have known that DOH!
I somehow expected physics to desist in my Drone 😄
Thanks all.
Edited by Monkspeed
