Esporova Posted October 17, 2019 Report Posted October 17, 2019 My Paranormal DNA 250c suddenly stopped hitting. It only hits when drenched and juice, and quickly stops heating up. Any help on fixing? Does Escribe have a juice detection setting, or maybe a battery setting that you can help me with? Truly appreciate any effort to fix this!
Esporova Posted October 18, 2019 Author Report Posted October 18, 2019 5 minutes ago, RVB2K said: Do you using TC or Replay? I use temp control. Built on a Digiflavor Mesh Pro RDA, SS 316L mesh wire. I am getting weak hits on TC, wattage, replay. All modes have the same issue. I don’t know how to fix this
RVB2K Posted October 18, 2019 Report Posted October 18, 2019 1 minute ago, Esporova said: I use temp control. Built on a Digiflavor Mesh Pro RDA, SS 316L mesh wire. I am getting weak hits on TC, wattage, replay. All modes have the same issue. I don’t know how to fix this If you using TC, you need check a resistance of the coil in cold temperature (room temperature). TC is working on the principle that the resistance of the coil changed with the warming the coil and so calculate right voltage/wattage. So, first, measure the coil resistance while it cold. This is the important point. Start your puff from 200F and up it by 5 degree up your best puff. Make sure that you don't overcome 250F. Do you receive any error on the screen?
Esporova Posted October 18, 2019 Author Report Posted October 18, 2019 29 minutes ago, RVB2K said: If you using TC, you need check a resistance of the coil in cold temperature (room temperature). TC is working on the principle that the resistance of the coil changed with the warming the coil and so calculate right voltage/wattage. So, first, measure the coil resistance while it cold. This is the important point. Start your puff from 200F and up it by 5 degree up your best puff. Make sure that you don't overcome 250F. Do you receive any error on the screen? I am not sure I understand? I turned my box to temp control SS 316L. I turned the heat down to 200 degrees Fahrenheit. I measured 0.15 ohms. I continued to do this all the way to 250 degrees. No error messages.
Lanzarotechris Posted November 16, 2019 Report Posted November 16, 2019 Is this problem solved ? @Esporova Does it hit now like expected or is there still a problem ?
Esporova Posted November 16, 2019 Author Report Posted November 16, 2019 5 hours ago, Lanzarotechris said: Is this problem solved ? @Esporova Does it hit now like expected or is there still a problem ? Still a problem. I don’t know what to do. I have determined it is definitely a problem with the box/mesh. I purchased a new mesh RDA and still have the same issues. I now went back to my goon dual coil RDA, running on watts mode with no problems. I seriously miss the mesh RDA... the flavor differences are greatly noticeable
zark Posted November 16, 2019 Report Posted November 16, 2019 В 18.10.2019 в 4:11 AM, Esporova сказал: I use temp control. Built on a Digiflavor Mesh Pro RDA, SS 316L mesh wire. То что Вы описываете похоже на плохой (недостаточный) контакт фитиля и mesh wire. или некачественный фитиль подает слишком медленно ( недостаточное количество) сок в зону испарения mesh wire. При недостаточно количестве сока на фитиле мод снижает мощность нагрева и получаете weak hits on TC
Lanzarotechris Posted November 19, 2019 Report Posted November 19, 2019 On 11/16/2019 at 12:48 PM, Esporova said: Still a problem. I don’t know what to do. Sorry to hear that. Can you provide us with some screenshots of the escribemonitor (when you puff on it), and maybe a photo of the coil build ?
drjohnson61 Posted November 20, 2019 Report Posted November 20, 2019 I would check resistance, cold, and then lock resistance, for TC.
Lanzarotechris Posted November 21, 2019 Report Posted November 21, 2019 16 hours ago, drjohnson61 said: I would check resistance, cold, and then lock resistance, for TC. That implies that everything else is ok. From the first post it looks like something is wrong.
