Hello fellow Modders,
I'm no expert in electronics and I'm hoping someone knows how we can wire properly an LED on the DNA 60 board for lighting it up when firing the mod.
Connecting it along with a resistor directly on the output to the atomizer , It Works but obviously depending on wattage selection the brightness varies and also it changes the atomizer resistance value that the board is reading.  (small soldering point are not really a problem as I've already replaces the tiny LED diode of the charging board with one of my preference and it works well)
If you know any other potential spots on the board with stable current when firing it and we could wire a 3V LED , I would greatly appreciate your help.
Thank you
  • 4 months later...
  • 1 month later...
Am 29.6.2019 um 18:34 schrieb ted@phoenikas.com:
Thank you
Have you got it to work?
