Evgeniy22 Posted March 19, 2019 Report Posted March 19, 2019 Hello. Help with the problem on the Dna250c. When I turn on the replay mode, nothing happens. No memorization of the couple, does not offer them to remember. Coils are ss + nich.
Wayneo Posted March 19, 2019 Report Posted March 19, 2019 Are the core wires SS or Nich? Best practices are Core wires are Temp controllable wires Using a Replay enabled theme, and in a replay enabled profile
Evgeniy22 Posted March 19, 2019 Author Report Posted March 19, 2019 Wrong. Now there is an internal cantal over nichrome
Wayneo Posted March 19, 2019 Report Posted March 19, 2019 Sorry? Who's wrong, what's wrong? First you said 38 minutes ago, Evgeniy22 said: Coils are ss + nich. Are you now saying your coils are 9 minutes ago, Evgeniy22 said: Now there is an internal cantal over nichrome Or do you not believe what I said were best practices?
Evgeniy22 Posted March 19, 2019 Author Report Posted March 19, 2019 I just remembered that I have other coils. And now the inner cantal braided nichrome. Could this affect that replay does not offer to remember the tightening?
Evgeniy22 Posted March 19, 2019 Author Report Posted March 19, 2019 1 минуту назад, Wayneo сказал: Follow what I suggested in my first reply I would love to, but the Russian language is such that it translates is not entirely correct. What materials are considered the best for replay? Thank you in advance
Wayneo Posted March 19, 2019 Report Posted March 19, 2019 Stainless Steel 3xx, 4xx. Ti01, Ni200, NiFe 48/52 AS THE CORE (DOMINANT) material/wire Not Nichrome.
Evgeniy22 Posted March 19, 2019 Author Report Posted March 19, 2019 9 минут назад, Wayneo сказал: Stainless Steel 3xx, 4xx. Ti01, Ni200, NiFe 48/52 AS THE CORE (DOMINANT) material/wire Not Nichrome. Thank you very much. Now I will try to rewind at home and show the result.
Evgeniy22 Posted March 20, 2019 Author Report Posted March 20, 2019 16 часов назад, Wayneo сказал: Stainless Steel 3xx, 4xx. Ti01, Ni200, NiFe 48/52 AS THE CORE (DOMINANT) material/wire Not Nichrome. Put the coils:inner(ss) +klepton nichrome. Replay still doesn't work. Does not fix puffs and does not show SAVE PUFF
dwcraig1 Posted March 20, 2019 Report Posted March 20, 2019 Make sure the Replay box is checked in EScribe for the profile that your using. While your in EScribe take note if there is a difference between cold ohms and live ohms while firing when using Device Monitor.
Evgeniy22 Posted March 20, 2019 Author Report Posted March 20, 2019 40 минут назад, dwcraig1 сказал: Make sure the Replay box is checked in EScribe for the profile that your using. While your in EScribe take note if there is a difference between cold ohms and live ohms while firing when using Device Monitor. The checkbox is worth it. There is a difference in monitoring between hot and cold when pressing faer. Cold 0.69. hot to 0.78
Evgeniy22 Posted March 20, 2019 Author Report Posted March 20, 2019 Now I put the drip in the mod. When hovering, save puff. I pressed to remember and caught fire that the soaring was remembered. When you press faer, an error appears: atomizer hek
awsum140 Posted March 20, 2019 Report Posted March 20, 2019 I'd suggest trying a simple, single wire coil made from only a TC material. You have not mentioned what atomizer you are using which can effect how stable the resistance remains.
Evgeniy22 Posted March 20, 2019 Author Report Posted March 20, 2019 18 минут назад, awsum140 сказал: I'd suggest trying a simple, single wire coil made from only a TC material. You have not mentioned what atomizer you are using which can effect how stable the resistance remains. I did ss + nichrome. Does not work
