DigitalSmoker Posted January 19, 2019 Report Posted January 19, 2019 Have a SXK BB DNA 60 and would like to re-flash the firmware. Is there a firmware download? Issue that i'm having is the resistance is jumping around on 3 different RBA's and can't use device manager in EScribe also. New to DNA boards so any info or suggestions/guidance would be appreciated. Thanks
Wayneo Posted January 19, 2019 Report Posted January 19, 2019 re-flash the firmware <- Already in Escribe. Tools - Service Pack. If it's not there, you can click the link in my sig. suggestions <- Youtube. djlsbvapes has good ones. Watch something for a non color DNA
ArminF Posted January 19, 2019 Report Posted January 19, 2019 (edited) Here you go: http://www.dna200.de/mac-escribe/ Latest ist SP19. And maybe import the battery curves as well. Helps the chip to know your battery better. But i still need to sit down with device monitor to find out the Punch Settings in % or Watt. And it would be so cool if we would be able to delete profiles. @Wayneo is there a Wishlist or Feature place where i could request the escribe software change to be able to delete unused profiles? I think i am not alone with this wish. Thank you! @DigitalSmoker i did configure the following profiles 1 - Watt - no punch 2 - Watt +3 Punch 3 - Watt +5 4 - Watt +7 5 - Watt +9 6 - Watt +11 7 - TC SS 316 - 40 Watt Preheat 8 - TC SS 316 - 50 Watt Preheat I do mostly use Watt so extended the punch into several profiles. While i am in TC i just need to adjust the Temperature then. Edited January 19, 2019 by ArminF
Wayneo Posted January 19, 2019 Report Posted January 19, 2019 On 1/19/2019 at 5:52 PM, ArminF said: is there a Wishlist or Feature place where i could request the escribe software change Expand https://helpdesk.evolvapor.com/index.php?a=add&category=5 While I'm here, just wondering WHY you continually send others offsite for the escribe software? It is officially published here by the author, in English, and without passwords? Link in my sig.
DigitalSmoker Posted January 19, 2019 Author Report Posted January 19, 2019 So even after re-flashing firmware issues still presist. Can not use device manager, display reads "check atomizer" and resistance still continues to fluctuate in wattage mode. Coil reads .46 on various other mods but on the SXK Billet Box it fluctuates anywhere between .42 to .48. Not sure if this is just a issue with BB's due to just poor connections with the key and housing of box. Any ideas out there? Thanks for your help-
ArminF Posted January 19, 2019 Report Posted January 19, 2019 (edited) @Wayneo thank you for the link i will open a suggestion. About the link to DNA Crew Germany and the escribe software. If i follow the link https://www.evolvapor.com/escribe i do end up with the SP17 which is not the latest. On DNA Crew link you will get the SP19 for download. That is the reason. Also i did found my batteries there. But i did check your link (which is very tiny formatted) and will keep in mind.@DigitalSmoker Does not look like a firmware issue. More like a contact or coil problem. If it is SS the resistance will change and get higher after the coil was heated up. Maybe check the top/Drip Tip Screw, clean the threads and contact. You can also try to restore factory settings through escribe but for me it looks more hardware coil related. Maybe the bridge has an issue. Can you try another bridge or coil? Edited January 19, 2019 by ArminF more details
AutomaticFailure Posted April 17, 2019 Report Posted April 17, 2019 I have the same issue with my resistance jumping on my epetite. This was after I got it back from escribe for repair, which I don't know if they didn't solder it correctly or what, but my resistance will jump anywhere as high as +.70
BB Fanboy Posted April 21, 2019 Report Posted April 21, 2019 On 1/19/2019 at 5:52 PM, ArminF said: Here you go: http://www.dna200.de/mac-escribe/ Latest ist SP19. And maybe import the battery curves as well. Helps the chip to know your battery better. But i still need to sit down with device monitor to find out the Punch Settings in % or Watt. And it would be so cool if we would be able to delete profiles. @Wayneo is there a Wishlist or Feature place where i could request the escribe software change to be able to delete unused profiles? I think i am not alone with this wish. Thank you! @DigitalSmoker i did configure the following profiles 1 - Watt - no punch 2 - Watt +3 Punch 3 - Watt +5 4 - Watt +7 5 - Watt +9 6 - Watt +11 7 - TC SS 316 - 40 Watt Preheat 8 - TC SS 316 - 50 Watt Preheat I do mostly use Watt so extended the punch into several profiles. While i am in TC i just need to adjust the Temperature then. Expand @ArminF This is a little bizarre that the evolv site has an older version of the firmware. Would have thought that the evolv website has the latest which makes me a little suspicious about the download from Pcloud ??? I would appreciate your comments. And another issue I'm having is i'm trying to get a copy of the original theme file from the Billet Box...eg. Doug Dino. Any ideas....obviously it can be copied directly off an original dna60 billet box but I don't know anyone near me with one. Any help would be much appreciated.
Wayneo Posted April 21, 2019 Report Posted April 21, 2019 On 4/21/2019 at 9:38 AM, BB Fanboy said: This is a little bizarre that the evolv site has an older version of the firmware. Would have thought that the evolv website has the latest which makes me a little suspicious about the download from Pcloud ??? I would appreciate your comments. Expand I'm not @ArminF, but that version of the software can be found right here. No password required. 1
ArminF Posted April 21, 2019 Report Posted April 21, 2019 Early Firmware can be downloaded as well here: I used and posted the German DNA Crew files. None modified versions as well. 1
BB Fanboy Posted April 21, 2019 Report Posted April 21, 2019 (edited) @ArminF and @Wayneo Thanks...yes after further research I did note that it was a bona fide software release but found that it was full of glitches etc. Have these now been ironed out? I suppose it seems unlikely as it hasn't been officially posted yet as an update. Thank you both for your responses...I am new to the DNA chip after getting the Lost Vape Drone and most recently the SXK billet box, both of which have made me a consummate fan. Cheers Charlie Edited April 21, 2019 by BB Fanboy
Wayneo Posted April 22, 2019 Report Posted April 22, 2019 Some 'glitches etc.' are real or mod specific, while some are merely new user misunderstanding. But you have the ability to roll backward or forward at your leisure. If your mods are both working fine, you do not need to upgrade either. You will note from the link I posted, the prior problems fixed and for which board type. 1
BB Fanboy Posted April 22, 2019 Report Posted April 22, 2019 @Wayneo Thanks for clarifying...I guess i'll leave it then if i'm not missing out on something new and exciting I don't suppose you know where to get a copy of the original Billet Box firmware do you ?? Thanks again.
Wayneo Posted April 22, 2019 Report Posted April 22, 2019 On 4/22/2019 at 12:08 PM, BB Fanboy said: I don't suppose you know where to get a copy of the original Billet Box firmware do you ?? Expand The 'firmware' on the OG is exactly the same as can be found here. I don't know if they even use the latest, but I could imagine that because they're an American manufacturer, to stay on the good side of the FDA, they'd not load the Intl. version. If you're talking customizations, it was all set for defaults, and the 8 profile settings were minimal. You're not really missing anything except a logo or 2. I do have a copy, but am not comfortable sharing, 1
BB Fanboy Posted April 22, 2019 Report Posted April 22, 2019 Yep...it's not for extra functionality it's merely for the original look....eg. the logos. You can PM me if you like...pretty please?
FAWKES-BB-N-DNA250C-LIPO Posted April 25, 2019 Report Posted April 25, 2019 id really like to get the doug dino logos myself, if anyone can share even just the logos so i can remake my own, please?
