Coyote Posted September 5, 2018 Report Posted September 5, 2018 As long as the wire has some kind of positive thermal coefficient, Replay just works! Even on my atomizers (Vandy Vape mesh RTA, Geek Vape Griffin) that sometimes give TC a fit. Evolv hit it out of the park with this one.
DMAN Posted September 15, 2018 Report Posted September 15, 2018 Just got the Hugsvape Lotus RTA and it doesn't work.
dandiele Posted November 8, 2018 Report Posted November 8, 2018 Just got my paranormal dna250c and so it doesn’t work on a falcon with f1 coil, a Valyrian or a uwell nunchaku. Kind of a bummer because I know for sure at least one of those uses a section of non resistance wire to the actual coil and that should be sufficient I thought for replay. Not gonna run around town buying coils / tanks to find one that works lol
DMAN Posted November 8, 2018 Report Posted November 8, 2018 On 9/15/2018 at 5:19 PM, DMAN said: Just got the Hugsvape Lotus RTA and it doesn't work. I should edit this post. The atty is working fine now that I understand Replay better. The coils I was using at the time had a Kanthal core. They worked on another DNA mod because I had allowed dubious coils. The Lotus is actually a pretty sweet atty with a restricted lung hit.
DMAN Posted November 8, 2018 Report Posted November 8, 2018 2 hours ago, dandiele said: Just got my paranormal dna250c and so it doesn’t work on a falcon with f1 coil, a Valyrian or a uwell nunchaku. Kind of a bummer because I know for sure at least one of those uses a section of non resistance wire to the actual coil and that should be sufficient I thought for replay. Not gonna run around town buying coils / tanks to find one that works lol Replay will only work with TC wires. In a fancy coil, the core needs to be a TC wire.
dandiele Posted November 8, 2018 Report Posted November 8, 2018 Right, I had just seen in a video we’re evolv mentioned it works with most combinations of wire and that since most sub ohm tanks use non resistance to connect to the actual coil be it kanthal or whatever that it should still work in that combo. It doesn’t appear to however at least on the coils I mentioned. I’m not really sure though of the coil wire used in them so not sure if it should be working. On the falcon you can clearly see in the coil a short section of thicker wire going to the actual coil
asmcriminal Posted November 8, 2018 Report Posted November 8, 2018 It has had issues with my Citadel.
NYVapes Posted December 3, 2018 Report Posted December 3, 2018 FYI: I use an Eleaf MELO 300 and the coil material isn't compatible with replay. Too bad because the mesh coil is one of the most flavorful coils I've ever vaped on and I've been vaping now close to 5 yrs.
