24k12k6k Posted August 27, 2018 Report Share Posted August 27, 2018 I just tried creating a couple themes and changed the fonts, added photos for the backgrounds etc. Now i want to create a new one but the device is out of space. How do I delete the themes that I've uploaded to free up space? Link to comment Share on other sites More sharing options...
Pphish Posted August 28, 2018 Report Share Posted August 28, 2018 8 hours ago, 24k12k6k said: Sorry guys I just figured out how to do this myself. I can't figure out how to delete this post. How did you do it?I didn't realize that themes accumulated on the device after a new one was loaded on... Link to comment Share on other sites More sharing options...
Pphish Posted August 28, 2018 Report Share Posted August 28, 2018 2 hours ago, 24k12k6k said: You have to close the theme designer, and open escribe. In escribe there is a button that says "restore defaults" this will delete all themes from the device. Yeah but that also removes all the profiles and material that I've added to the device. Are you certain that the device stores old themes that you are no longer using? If so that seems like a bit of an oversight on the part of Evolv... Sounds like something should be remedied in the next firmware update ( @James) Link to comment Share on other sites More sharing options...
retird Posted August 28, 2018 Report Share Posted August 28, 2018 I believe when you upload a different theme the other one is gone.... Multiple themes are not stored on the device... 1 Link to comment Share on other sites More sharing options...
retird Posted August 28, 2018 Report Share Posted August 28, 2018 41 minutes ago, 24k12k6k said: No your wrong Why do you think the device stores multiple themes? Here is an older tutorial for the 75C and the 250C is similar as far as Theme Designer.... Link to comment Share on other sites More sharing options...
Coyote Posted September 2, 2018 Report Share Posted September 2, 2018 The space used is telling you how much space will be used by the theme you are designing. You're being told you are out of space because the theme you are making is too big for the device. I think (but I'm not sure) the only thing the device accumulates over time is the puff recordings. When you upload a larger theme you might lose the oldest recordings if they are taking space the theme needs. Link to comment Share on other sites More sharing options...
