iambyrdman Posted August 12, 2018 Report Share Posted August 12, 2018 (edited) I'm getting No Temperature Reading on a Peranormal 250C. Tried restoring defaults. I'm using 316L with this file ~SS316L~.csv . Any thoughts? Here's Device Monitor showing 3 puffs Edited August 12, 2018 by iambyrdman Link to comment Share on other sites More sharing options...
iambyrdman Posted August 12, 2018 Author Report Share Posted August 12, 2018 This is a device I built so I think I know how it works... Link to comment Share on other sites More sharing options...
iambyrdman Posted August 13, 2018 Author Report Share Posted August 13, 2018 I'm just having a bad luck run. Now this one I built isn't cutting off when it hits temperature... Link to comment Share on other sites More sharing options...
retird Posted August 13, 2018 Report Share Posted August 13, 2018 I wonder if it could be the atty, coill, or a wiring issue.... If I recall when you built #2 it wouldn't read TC either.... Link to comment Share on other sites More sharing options...
Wayneo Posted August 13, 2018 Report Share Posted August 13, 2018 Can ya describe your coil. Link to comment Share on other sites More sharing options...
iambyrdman Posted August 13, 2018 Author Report Share Posted August 13, 2018 I'm using SS316L. I usually build coils where I'll spin more than one wire together but I have found them to be less stable. However I get the same results out of simple round wire builds. At this point I'm wondering if I'm getting bad wire maybe. I should break out an out Uwell Crown and see if that changes anything. It's approved for Replay is why I'm thinking that. Link to comment Share on other sites More sharing options...
Wayneo Posted August 13, 2018 Report Share Posted August 13, 2018 Alrighty, can you do one last printscreen while taking a puff. Using the mod in that last Printscreen (ByrdBuild#2). Same atty and coil used there. Using your Profile 7 like in the PS, but ONLY with these checkboxes ticked. Link to comment Share on other sites More sharing options...
iambyrdman Posted August 13, 2018 Author Report Share Posted August 13, 2018 3 hours ago, Wayneo said: Alrighty, can you do one last printscreen while taking a puff. Using the mod in that last Printscreen (ByrdBuild#2). Same atty and coil used there. Using your Profile 7 like in the PS, but ONLY with these checkboxes ticked. Seems even more out of hand than last try. Why isn't it stopping at set temperature? Link to comment Share on other sites More sharing options...
Wayneo Posted August 13, 2018 Report Share Posted August 13, 2018 Can ya do a full printscreen of your Profile 7 Link to comment Share on other sites More sharing options...
