Running MacOS Mojave, launching the EScribe Suite shows the bouncing icon in the dock for a few seconds and disappears.
Output from running '/Applications/EScribe\ Suite.app/Contents/MacOS/Main.app/Contents/MacOS/RunProgram' in the terminal:
Initializing MacOS...
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.200.2/Common/ChunkCompression.cpp:49: Error: unsupported compressor 8
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.200.2/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/Exceptions.plist'
/BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleFSCompression/AppleFSCompression-96.200.2/Libraries/CompressData/CompressData.c:353: Error: Unknown compression scheme encountered for file '/System/Library/CoreServices/CoreTypes.bundle/Contents/Library/AppExceptions.bundle/Exceptions.plist'
Starting run loop
Started run loop
Stopping run loop
Stopped run loop
Benchmark: Settings took 157,3373 ms.
Benchmark: Register took 41,3491 ms.
Benchmark: Language took 69,9515 ms.
Benchmark: Decrypt resource: Branding took 112,5386 ms.
Benchmark: Decrypt resource: Branding took 82,0589 ms.
Benchmark: Decrypt resource: Icons took 106,0795 ms.
Downloader: Waiting to be asked to check
Benchmark: Early Initialization took 537,4184 ms.
Starting run loop
Started run loop
Benchmark: Decrypt resource: Main took 83,8541 ms.
Benchmark: Tracking: Main took 7,5869 ms.
Benchmark: Main Form Load Snappy took 769,6031 ms.
Benchmark: Main Form Load took 798,1869 ms.
Benchmark: Main Form Wiring took 5,546 ms.
Downloader: Requesting update info
Benchmark: Decrypt resource: Welcome took 78,3893 ms.
Benchmark: Requesting resource list took 543,9601 ms.
Benchmark: Decrypt resource: Branding took 71,8393 ms.
Benchmark: Tab Configuration: Welcome took 45,1353 ms.
Benchmark: Load Features: Tab Page (Welkom) took 7,3876 ms.
Benchmark: Load Features: Tab Page (Welkom) took 2,6677 ms.
Benchmark: File->New took 34,4529 ms.
Benchmark: Main Form Init End took 37,3037 ms.
Benchmark: Main Form Init took 1085,6192 ms.
Benchmark: Main Form Creation took 1884,6155 ms.
Unhandled Exception:
System.NotSupportedException: MonoMac.AppKit.NSView
  at (wrapper managed-to-native) MonoMac.ObjCRuntime.Messaging:void_objc_msgSend (intptr,intptr)
  at MonoMac.AppKit.NSApplication.Run () [0x00018] in <f6179a3f9e4948348bf38b57cebc82e8>:0
  at A.YW.De (System.Action ) [0x00066] in <ebdf68d56e6d4ed8bacae302c89f471e>:0
  at E.OA.b (System.String , System.Func`1[TResult] , System.Func`2[T,TResult] , System.Action ) [0x00062] in <d5a7a87f9d8a43f485311c715e179ffc>:0
  at B.NN.q (S.Dr ) [0x0004d] in <861506600def48989bb872c3fae88169>:0
  at B.Na.N (S.Dr ) [0x00000] in <861506600def48989bb872c3fae88169>:0
  at S.DA.q (System.String , S.Dr ) [0x000ae] in <308620eca5df47b488dd71340524707e>:0
  at B.ND.o (System.String[] ) [0x00bb1] in <861506600def48989bb872c3fae88169>:0
  at B.ND+NP.P () [0x00000] in <861506600def48989bb872c3fae88169>:0
  at E.OA.DS (System.Action ) [0x00000] in <d5a7a87f9d8a43f485311c715e179ffc>:0
  at A.YW.DS (System.Action ) [0x00011] in <ebdf68d56e6d4ed8bacae302c89f471e>:0
  at E.OA.wh (System.Action ) [0x00006] in <d5a7a87f9d8a43f485311c715e179ffc>:0
  at B.ND.t (System.String[] ) [0x0016b] in <861506600def48989bb872c3fae88169>:0
System.InvalidOperationException: Called from uninitialized thread.
  at (wrapper managed-to-native) MonoMac.ObjCRuntime.Messaging:void_objc_msgSend_IntPtr (intptr,intptr,intptr)
  at MonoMac.AppKit.NSApplication.Terminate (MonoMac.Foundation.NSObject sender) [0x00034] in <f6179a3f9e4948348bf38b57cebc82e8>:0
  at A.YW.xW () [0x00010] in <ebdf68d56e6d4ed8bacae302c89f471e>:0
  at E.OA.kJ () [0x00062] in <d5a7a87f9d8a43f485311c715e179ffc>:0
  at e.Z.ar () [0x00005] in <3613928291b64310b00daae9eb5ee563>:0
  at B.ND.t (System.String[] ) [0x0026c] in <861506600def48989bb872c3fae88169>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.InvalidOperationException: Called from uninitialized thread.
  • 1 month later...
  • 1 month later...
i have tried to uninstall the old version 2.o SP 15 and install. the last with the SP 17 but still doesn't work on Mojave, the SP17 add only the support for DNA Go, I have tried on windows.
I keep my fingers crossed for a new version
Well Escribe is a 32 Bit architecture App which Apple is in the process of getting rid off. In future only 64 Bit apps will be supported.
Edited by McGee
Yes, I know... the big question is WHEN will Evolve launch a new running Escribe Software (64bit) for MacOS Mojave? Hopefully soon, but unfortunately there is no light at the end of the tunnel so far.
I've posted an early EScribe Suite providing Mojave compatibility.
It also makes the software 64-bit on MacOS to avoid future compatibility issues. Let me know if you run into any bugs with it.
Thanks!
James
  • Thanks 1
