Brad S Ruttenberg Posted June 7, 2018 Report Posted June 7, 2018 i have mod thermal values but the test were done at a temp5 deg higher than my room and 5 deg higher than 70F so how do i plug them in the right spaces and let the mod know these are values at 75.2 deg f not at 70?? or doesnt it matter?
Brad S Ruttenberg Posted June 7, 2018 Author Report Posted June 7, 2018 5 hours ago, Brad S Ruttenberg said: i have mod thermal values but the test were done at a temp5 deg higher than my room and 5 deg higher than 70F so how do i plug them in the right spaces and let the mod know these are values at 75.2 deg f not at 70?? or doesnt it matter? I didnt run the case analyzer someone else ran it on their mod and posted values the room they ran at was 75.2F i can not run it on mine as it trickle charges shows a .0002-0004 continuos charge or temp change due too charge ... so since i cant run it andf the data i have was ran at a much higher room temp can i use the nubers?
retird Posted June 7, 2018 Report Posted June 7, 2018 Make a backup copy of your ecig file before making any changes....I think you should be fine using it as a lot of folks do that....... best if you can run your own analyzer....
Brad S Ruttenberg Posted June 7, 2018 Author Report Posted June 7, 2018 (edited) 45 minutes ago, retird said: Make a backup copy of your ecig file before making any changes....I think you should be fine using it as a lot of folks do that....... best if you can run your own analyzer.... of course i have a backup copy .. I have a .003 amp trickle its not enough to charge but it is enough to keep the mod from ever getting a good case thermal.. .. as theres a continous low amp trickle and a consistent temp inc /fluctuation because of it as the gentleman mentions on this its enough to keep the temp of the case skewed and elevated... so is that a problem with the board? do i talk to evolv? it should be 0.000 amp when running case analyzer Edited June 7, 2018 by Brad S Ruttenberg
retird Posted June 7, 2018 Report Posted June 7, 2018 You can always start a ticket with Evolv....Explain your concern and they will guide you.... Your battery was only 1/2 full when you started Analyzer right? What do you mean "one more time for the cheap seats"....?
Brad S Ruttenberg Posted June 7, 2018 Author Report Posted June 7, 2018 sorry for the chape seatrs comment i got a email that someone had replied in a way indicating profound lack of understanding of the issues i was having i edited the comment as the comment it was refering to doesnt seem to be on the thread.. and it was out of frustration and not fair.. now .. i might start an evolv ticket thank you for the info.. ..and no i actually did it when the batt was close to full... .. it might make a difference so ill wait til the batt is half discharged and THEN ill re try case analyzer maybe the trickle charge wont happen if its not nearly full... ill try again and post whether i had success with half drained batts or.. if it was the same result and if i needed to start an evolv ticket
retird Posted June 7, 2018 Report Posted June 7, 2018 Yep, do let us know what you get with a 1/2 full battery to start.... The guy in the video you posted didn't say anything (unless I missed it) about starting with a battery at about 1/2 charged....
Brad S Ruttenberg Posted June 7, 2018 Author Report Posted June 7, 2018 (edited) 8 minutes ago, retird said: Yep, do let us know what you get with a 1/2 full battery to start.... The guy in the video you posted didn't say anything (unless I missed it) about starting with a battery at about 1/2 charged.... i will try it with 1/2 charge... and let you know... and no he didnt but the video comments i was refering to were his comments about some chinese mods having a trickle amp.005ish and never just reaching 0.000 which throws off thermals etc and makes the diagonostic test hard to run cause it doesnt stablise the temp back down over 30 min...(from the heat up start...)..etcid assume the .003amp trickle wouldnt be a huge variance? if i could get the diagnostics to complete which it wont since it expects and needs to see 0.000 amps.. .. also it occurs to me that since the .003-005 amp trickle is a characteristic of my mod.. having it figured in the case analyzer would be okay .. iuf i could actually get the case thermals test to run.. and finish which is the probklem right now it wont cause it expects to see 0.000amps and expectsa the case to drop somewwhere close to ambi temp.. right now cause of the trickle charge it fluctuates Edited June 7, 2018 by Brad S Ruttenberg
retird Posted June 7, 2018 Report Posted June 7, 2018 Yes, I have seen a few posts along the way where this trickle you speak of is talked about.... none of my 7 DNA's do that during analyzer... I don't know if a trickle is figured into the analyzer function or not..... good question..... and i wonder how much difference it would make by just being 3 one-thousands of an amp? And could it be a design issue with the wiring/grounding/etc of the device?? Have a good one and let us know what goes with your analyzer ....
Wayneo Posted June 7, 2018 Report Posted June 7, 2018 1 hour ago, retird said: The guy in the video you posted didn't say anything (unless I missed it) about starting with a battery at about 1/2 charged.... 1 hour ago, Brad S Ruttenberg said: and no he didnt Sure he does, right around 1 min 50 second mark
Brad S Ruttenberg Posted June 7, 2018 Author Report Posted June 7, 2018 Okay h3,does. But that doesn't really affect my question I mean it's possible he does but my concern is more with the weird trickle amperage or can I use the results from somebody else who has the same mod I do even if the ambient temperature they tested them in was 75.2 degrees cuz I could plug in those values and be much much closer than evolve defaults but there's no way when you plug in values manually to indicate what the ambient temperature the test was run at you know like I said whether the guy at the video said half charged or not is really an incredibly tangential issue
GHammer Posted June 8, 2018 Report Posted June 8, 2018 Just run the batteries down to less than 50% and do your case thermals.
Herbestos Posted June 15, 2018 Report Posted June 15, 2018 This is an issue I also have. I built my own mod with a 4s lipo and can’t see how this is down to mod price (also watched his videos) as the USB port is part of the board and only be evolvs issue of it was faulty. Also In device monitor if I turn the charging off it shows 0.000a but not on case analyser which shows this leakage. It has a big effect on temp as I left the mod to acclimatise all night and all day and as it was waiting to reach a steady temp it went up over 10 Fahrenheit before the half hour was up so that trickle charge really dose raise the temp. Maybe I should also open a ticket but if you find out a resolve it would be great if you could share it here. Thanks.
