sessions Posted December 5, 2017 Report Share Posted December 5, 2017 (edited) hoping i could get some help with my Lost Vape Efusion DUO DNA200. For some reason the lipo battery went down to 0% last night (ive never seen it go lower than 10%) so i charged it and went to use it this morning and it said SHORTED and the battery level was still 0%. Just got home from work and it no longer says shorted but when i hit the fire button the welcome screen will flash for 1second and then go black (still at 0%). I cant get it to charge via the computer or wall port. Anyone have any ideas? Did my lipo die? its only a few months old. device monitor: https://i.imgur.com/EHzjxvT.png csv.csv Edited December 5, 2017 by sessions Link to comment Share on other sites More sharing options...
DharamKapadia Posted January 11, 2018 Report Share Posted January 11, 2018 Ditto problem... did u manage to fond a solition to it? frankly i am very upset with these expensive mods just dieing on you worh light use... please do update if u find a solution thanks Link to comment Share on other sites More sharing options...
Coyote Posted January 23, 2018 Report Share Posted January 23, 2018 If the board is reporting the cell voltages correctly, the pack is discharged below safe limits. You could try recovery charging, but it might be time for a new battery. You could also have a board failure or a bad ground. I had this happen in a VT250s, it needed the battery and 510 wires resoldered. Link to comment Share on other sites More sharing options...
DharamKapadia Posted January 23, 2018 Report Share Posted January 23, 2018 So much for a few months old mod. Have used it sparingly for 4 months. Have paid over 190 bucks for this device. So this device is not thag great as it looks from the outside. Really sad will surely get it checked. thanks for your suggestion Link to comment Share on other sites More sharing options...
Sam Lowry Posted January 30, 2018 Report Share Posted January 30, 2018 Well if your mod really is bricked, I wonder how hard it would be to open up and swap in a new DNA board. It won't be easy, but I would imagine that would HAVE to fix it. Link to comment Share on other sites More sharing options...
Coyote Posted January 30, 2018 Report Share Posted January 30, 2018 Well it will fix it... but it might fail again. In my case the mod (vt250s) had the 510 shorting to the custom board that switches between 2/3 batteries. That was causing all kind of odd things to happen, and eventually killed a DNA board. In my experience, the SHORTED isn’t a fatal issue. Check the wiring and soldering. Link to comment Share on other sites More sharing options...
