tarunprakashsingh Posted November 10, 2017 Report Share Posted November 10, 2017 Guys, few things wrong with mod. 1. As soon as I sqounk the mod shuts down, starts only when i take battery out and put again. Then works fines till i have to sqounk again. 2. Battery charges only to 87-91% only. Help is needed urgently... Link to comment Share on other sites More sharing options...
retird Posted November 10, 2017 Report Share Posted November 10, 2017 Do you get an error message when it shuts down and you try to fire it? Link to comment Share on other sites More sharing options...
tarunprakashsingh Posted November 10, 2017 Author Report Share Posted November 10, 2017 No error no message just shuts off Link to comment Share on other sites More sharing options...
retird Posted November 10, 2017 Report Share Posted November 10, 2017 Could there be a loose connection in the battery tray? Squonk may move the batteries a bit.... can you hold the bottle outside of the device and squonk it and see if it shuts down that way also? Link to comment Share on other sites More sharing options...
tarunprakashsingh Posted November 10, 2017 Author Report Share Posted November 10, 2017 Will try that... Link to comment Share on other sites More sharing options...
tarunprakashsingh Posted November 10, 2017 Author Report Share Posted November 10, 2017 How can i send it to evolv to check and repair? Some one told me it can be done. Link to comment Share on other sites More sharing options...
retird Posted November 10, 2017 Report Share Posted November 10, 2017 3 minutes ago, tarunprakashsingh said: How can i send it to evolv to check and repair? Some one told me it can be done. Start a ticket with Evolv and they will guide you... https://helpdesk.evolvapor.com/index.php?a=add&category=1 1 Link to comment Share on other sites More sharing options...
Wayneo Posted November 10, 2017 Report Share Posted November 10, 2017 If you remove the squonk bottle and the battery is there eliquid inside the box itself? Link to comment Share on other sites More sharing options...
tarunprakashsingh Posted November 10, 2017 Author Report Share Posted November 10, 2017 So i took rda off. Used compressed air on 510. Lot of juice came out. Cleaned it and now its working. I feel juice is leaking in btw 510 and rda on to 510... not sure how to fix it Link to comment Share on other sites More sharing options...
Wayneo Posted November 10, 2017 Report Share Posted November 10, 2017 I don't own a Therion, but for squonkers there are 2 types of connections. One 510 pin (in the mod) is spring loaded, so various rda's will push on it and make a sealed connection to help prevent leakage. The other you need to adjust the 510 in the mod and rise/lower for each different rda to ensure a sealed connection. Bit of maintenance keeping everything clean is essential. Isopropyl alcohol and QTips are your friend. Compressors work too, but might not totally clean that VG. Link to comment Share on other sites More sharing options...
tarunprakashsingh Posted November 10, 2017 Author Report Share Posted November 10, 2017 It is spring loaded... but still leaks some how. Will try another rda and see if it because of rda or mod... cleaning with alcohol will take away VG? Link to comment Share on other sites More sharing options...
Wayneo Posted November 10, 2017 Report Share Posted November 10, 2017 I have only used Isopropyl alcohol, vinegar, or windex Link to comment Share on other sites More sharing options...
PKT Posted November 26, 2017 Report Share Posted November 26, 2017 I also had juice get into my brand new Paranormal DNA75C, I thought the 510 was sealed but when set upside down for a couple of hours a disturbing amount came out. I was using the KYLIN which was new to me as well. I took it off and onto an older mod until I figure out it's deal. Luckily it still works, the temp control went a bit wonky but that may be my coil. Does anyone know if the board & important guts are sealed off from the 510 connection? You can't get into this thing. Link to comment Share on other sites More sharing options...
