Therion BF DNA75C
tarunprakashsingh
I don't own a Therion, but for squonkers there are 2 types of connections. One 510 pin (in the mod) is spring loaded, so various rda's will push on it and make a sealed connection to help prevent leakage. The other you need to adjust the 510 in the mod and rise/lower for each different rda to ensure a sealed connection.
Bit of maintenance keeping everything clean is essential. Isopropyl alcohol and QTips are your friend. Compressors work too, but might not totally clean that VG.
  • 3 weeks later...
I also had juice get into my brand new Paranormal DNA75C, I thought the 510 was sealed but when set upside down for a couple of hours a disturbing amount came out. I was using the KYLIN which  was new to me as well. I took it off and onto an older mod until I figure out it's deal.
Luckily it still works, the temp control went a bit wonky but that may be my coil. Does anyone know if the board & important guts are sealed off from the 510 connection? You can't get into this thing.
