RichterR Posted July 21, 2017 Report Posted July 21, 2017 Hello, i've recently purchased a VT Inbox by HCigar (DNA75). I love the device so far but it is almost unusable with dual coil builds or builds that tend to get a bit hot. I've started with a Maze V4 and a Wotofo Serpent BF both in DC->After 3 drags the device threw out a "Too Hot" Message. The Board Temp was about 190F, the initial Board Temp was 89F. After switching to single coil builds and doing more pauses bewteen the drags it all worked fine but when i tend to vape a "lot" (Lets say 6 drags in 5 Minutes, the device still throws a "Too Hot Message". What can i do to fix this? Im currently using a Pulse RDA with Stagged Claptons (0.3) on 75W. I vaped higher amp builds on my other cheaper devices without having issues, its realy annoying. Another strange thing is that usualy the "Too Hot" message is thrown at arround 190F Board Temp but this is kinda unrealiable as well today i got one at 170F. Has anyone experienced such an issue? Ive checked the forum but havent found a solution. I've already applied the latest service packs and reflashed the firmware. What else can i do? wbr Robin
Wayneo Posted July 21, 2017 Report Posted July 21, 2017 This sounds like it could be battery/connection issue you're experiencing. Is your battery new/used, on Mooch's recommended list?
RichterR Posted July 21, 2017 Author Report Posted July 21, 2017 Hello, it's a used one, a Sony Konion VTC5, i've tried out a brand new LG HG2 with the same result.
RichterR Posted July 21, 2017 Author Report Posted July 21, 2017 Nope, I'm cleaning it after every vape (it's kinda spleen:)) and when refilling I'm always putting a towel between the squonk bottle and the inhousing. By the way, currently the mod is not heating up so fast...very strange
Degree Posted February 14, 2018 Report Posted February 14, 2018 Hello! Does anyone know if the problem is solved? I have the same problem with overheating on Nsigar 75D. I use 45 watts and after 5 puffs the board temperature rises to 72 degrees Celsius. After which the protection is triggered
Mark82 Posted October 7, 2018 Report Posted October 7, 2018 same problem here on my vicious ant primo 26650 ti which is like a week old i put a battery in after letting it sit overnight and the board temp is saying 170f wtf? im lucky to get 1 puff before 'TOO HOT" pops on the screen. there is no way the board can be that hot.... updated service pack did a hard reboot still nothing..... HELP!!!
retird Posted October 7, 2018 Report Posted October 7, 2018 Did it immediately say "too hot" when you put in the battery? When you put in the battery were you able to fire the mod? Does it show "too hot" after installing the battery without an atty attached and not firing device for a minute or two? Atty attached make any difference? Any other information may help....
Mark82 Posted October 7, 2018 Report Posted October 7, 2018 it did fire immediately 1 time before too hot was displayed . loaded battery and pressed button12 hours later i pop a battery in and its too hot immediately.. even when i plugs the usb in with no battery in the mod it reads 190s-low 200s F.. THE ROOM TEMP READS 110 always in my room that is about 65f.
retird Posted October 7, 2018 Report Posted October 7, 2018 hum, about a week old.... contact the vendor/mod maker.... that's an expensive work of art and they should correct the issue I would think..... sounds like something could be shorted out.... let us know what resolve you get from the mod maker/vendor....
retird Posted October 7, 2018 Report Posted October 7, 2018 Found this on their web site.... you can also use their "contact us" link on the web page.... https://viciousantonline.com/about-us/
