Hey there peoples. Been trying to get Stainless "working" in TC for a few hours and I am running out of ideas.
:: I have added the material from steam-engine.org's CSV file and edited a profile to change the material to the new 316L.
:: I have made a spaced, 0.89Ohm coil
:: Did NOT dry burn
:: Temp set to 250C and 50w and watched as the cotton burst into flames
Using a cloned Kayfun 5 and a Nalu dripper and getting the same results. The wire is UD 28g 316L.
Any advice?
My thoughts are as follows, either the wrong TCR or a horrible connection somewhere between the board and the coil. K5's are known to have a slightly shorter 510 so a wonky connection between the M - F 510 is quite possible.
I'd also side with DW, and speculate that the chip is not seeing the wire as TCR and firing in strictly power mode.  Screen prints of device monitor will make a constructive answer a lot easier.
Hi, I have the same problem and I just set the temp. at 210 C 55wats for my 0.2 dual core ss316l Clapton  (0.3x1 coil) 26 ga+30ga wire
lock the resistance when was cold. all fine now.
  • 2 months later...
