Smokin Dave Posted July 9, 2017 Report Posted July 9, 2017 I'm using Efest 26650 3.7V batteries for my Hcigar VT75C and started getting a weak battery message even though there is 75% or higher battery life remaining.I looked in escribe for the battery type and there are the two usual choices of 18650 Lithium Ion and Lithium Polymer.I've never used 26650's before and was wondering if there is a csv battery profile for the 26650 that I should be using or just ignore the message.Maybe I should run the battery analyzer.I don't know.I need expert advice.Thanks.
Lowbytes Posted July 9, 2017 Report Posted July 9, 2017 EFEST - weak bat reason......beside that no 26650 is really good Enercig 26650 is far better - not breaking down under load that fast! Best way - doing your own cell analysis
Smokin Dave Posted July 12, 2017 Author Report Posted July 12, 2017 Yeah.Ok.Thanks.The reason I went with the Efest Green 26650 was on Mooch's recommendation.Maybe I'll stick in the 18650 adapter and give that a go.
James Posted July 12, 2017 Report Posted July 12, 2017 Battery curves affect the battery meter accuracy but do not affect battery life or performance at all. Weak Battery means the battery voltage has dropped down to 2.75V (Mod -> Battery -> Soft Cell Cutoff) and the device is reducing power to a level the battery can handle so that it can use the rest of the battery's charge. Hmm. Looking at https://www.e-cigarette-forum.com/forum/attachments/image-jpg.523804/ the 30A discharge barely touches 2.75V except at the end. The 15A discharge, https://www.e-cigarette-forum.com/forum/attachments/image-jpg.523764/, should hold 35-40W all the way to the end of its capacity. (Are you sure the batteries you got are genuine and brand new? Hmm, other ways you could get voltage losses... is the battery contact good and the wiring reasonably sized?) 1
Smokin Dave Posted July 13, 2017 Author Report Posted July 13, 2017 The batteries are new going on two weeks old and they are genuine.The current cell voltage reading is 3.8V at 71% charge according to what I see on the battery info screen.I'm going to switch to an 18650 to see what happens.It is performing as I expect it to and I'm not disappointed.
Lowbytes Posted July 13, 2017 Report Posted July 13, 2017 If it is a HCIGAR VT75C try to clean the threading of the Bat cover and the inner thread witch alcohol We´ve had such issues due some production residues - after cleaning the problem was gone!
Smokin Dave Posted July 14, 2017 Author Report Posted July 14, 2017 Thanks.Yes I've done the alcohol cleaning thing plus I noticed the positive connector is spring loaded and jacked that around a few times.The problem seems to resolved.
Droopydroors Posted July 15, 2017 Report Posted July 15, 2017 I was getting week battery with the Efest 26650 ( green & purple) at around the 45% mark. I purchased the Ijoy 26650 and haven't had a problem since. This battery has much less sag than the other 26650 it acts much more like an 18650. 1
Smokin Dave Posted July 15, 2017 Author Report Posted July 15, 2017 I gotta couple of Ijoy's coming right now.They are also on Mooch's list as being reliable and genuine.We'll see how they fare compared to the Efest batts.
Smokin Dave Posted August 3, 2017 Author Report Posted August 3, 2017 Well I give up.It stopped for a while but once again I cannot stop the weak battery screen from coming up after each and every hit I take off of this POS.It still hits like a champ and that's all I really want but I've tried everything from exercising the spring loaded battery pin cleaning the threads on the battery door swapping out the themes bla bla bla.Guess it's something I'll have to live with but for the price I paid I shouldn't have too.
dwcraig1 Posted August 3, 2017 Report Posted August 3, 2017 The spring loaded positive battery connector looks like a place to be looking for your problem provided battery door threads are doing their job, just my opinion though, this video may help. (at 8:23)
