Del-1882 Posted June 7, 2017 Report Share Posted June 7, 2017 Hi peeps, just got my first dna 74 mod today (aimidi etaliens x3) ive put in fresh new batteries straight away (18650) mod says check battery. so far ive tried 6 other fully charged batteries and it still says the same thing. also downloaded the software from evolve and updated my mod but nothing seems to help. any help and advice would be most appreciated. thanks Link to comment Share on other sites More sharing options...
VapingBad Posted June 7, 2017 Report Share Posted June 7, 2017 Look in device monitor in EScribe to check the battery voltage is reading correctly. Link to comment Share on other sites More sharing options...
giz_60 Posted June 7, 2017 Report Share Posted June 7, 2017 On 6/7/2017 at 4:43 PM, Del-1882 said: Hi peeps, just got my first dna 74 mod today (aimidi etaliens x3) ive put in fresh new batteries straight away (18650) mod says check battery. so far ive tried 6 other fully charged batteries and it still says the same thing. also downloaded the software from evolve and updated my mod but nothing seems to help. any help and advice would be most appreciated. thanks Expand What kind of batteries? Can you post a screenshot of the 'Mod' tab in Escribe? 1 Link to comment Share on other sites More sharing options...
Del-1882 Posted June 8, 2017 Author Report Share Posted June 8, 2017 On 6/7/2017 at 6:14 PM, VapingBad said: Look in device monitor in EScribe to check the battery voltage is reading correctly. Expand ok I can do that but I'm new to this so I wouldn't know if it reads it correct or not.....I did notice last night it said o.23v Link to comment Share on other sites More sharing options...
Del-1882 Posted June 8, 2017 Author Report Share Posted June 8, 2017 On 6/7/2017 at 7:02 PM, giz_60 said: What kind of batteries? Can you post a screenshot of the 'Mod' tab in Escribe? Expand yeah I can do that......I will do it shortly Link to comment Share on other sites More sharing options...
giz_60 Posted June 8, 2017 Report Share Posted June 8, 2017 On 6/8/2017 at 12:38 PM, Del-1882 said: yeah I can do that......I will do it shortly Expand And a screenshot of 'Device Monitor' would be helpful as well! 1 Link to comment Share on other sites More sharing options...
Del-1882 Posted June 8, 2017 Author Report Share Posted June 8, 2017 I'm using LG HG2 18650 and Samsung 30Q 18650 Link to comment Share on other sites More sharing options...
Del-1882 Posted June 8, 2017 Author Report Share Posted June 8, 2017 first photo was taken immediately, the 2nd less than a minute later Link to comment Share on other sites More sharing options...
Wayneo Posted June 8, 2017 Report Share Posted June 8, 2017 Whew baby. For starters change that 'cell soft cutoff' value to 2.8v, upload to device, and see how that helps Link to comment Share on other sites More sharing options...
Del-1882 Posted June 8, 2017 Author Report Share Posted June 8, 2017 On 6/8/2017 at 1:13 PM, Wayneo said: Whew baby. For starters change that 'cell soft cutoff' value to 2.8v, upload to device, and see how that helps Expand ok cheers Wayneo, I will give that a go now and let u know Link to comment Share on other sites More sharing options...
Wayneo Posted June 8, 2017 Report Share Posted June 8, 2017 Follwed by, or also update your firmware. In your 1st screen shot in dark blue, it says to upload Link to comment Share on other sites More sharing options...
Wayneo Posted June 8, 2017 Report Share Posted June 8, 2017 Then another printscreen of device monitor while firing. Lose the board temp tick, add the green 'power' tick. Link to comment Share on other sites More sharing options...
Del-1882 Posted June 8, 2017 Author Report Share Posted June 8, 2017 On 6/8/2017 at 1:26 PM, Wayneo said: Then another printscreen of device monitor while firing. Lose the board temp tick, add the green 'power' tick. Expand still saying check battery Link to comment Share on other sites More sharing options...
Wayneo Posted June 8, 2017 Report Share Posted June 8, 2017 (edited) Sounds like a battery connection wiring or grounding issue. Can you check any external screws around the battery compartment Showing .2V yet, in an earlier post your battery showed ~4v? Edited June 8, 2017 by Wayneo 1 Link to comment Share on other sites More sharing options...
Del-1882 Posted June 8, 2017 Author Report Share Posted June 8, 2017 On 6/8/2017 at 1:44 PM, Wayneo said: Sounds like a battery connection wiring or grounding issue. Can you check any external screws around the battery compartment Expand to be honest that was the first thing I thought of mate Link to comment Share on other sites More sharing options...
Wayneo Posted June 8, 2017 Report Share Posted June 8, 2017 Make sure that bottom battery screw is firmly snug, not Superman tight. Link to comment Share on other sites More sharing options...
Del-1882 Posted June 8, 2017 Author Report Share Posted June 8, 2017 yeah ive just double checked, so basically my settings are fine?? a flat battery is flat so learly a connection problem as u say. obviously I'm gonna have to send it back to the vendor which is what I wanted to avoid Link to comment Share on other sites More sharing options...
Wayneo Posted June 8, 2017 Report Share Posted June 8, 2017 Yes, for the most part, your settings are now current, and fine (except for your mod resistance which is not relevant for this). Much wiser to work with your vendor then manufacturer before opening it up. Link to comment Share on other sites More sharing options...
Del-1882 Posted June 9, 2017 Author Report Share Posted June 9, 2017 On 6/8/2017 at 7:28 PM, Wayneo said: Yes, for the most part, your settings are now current, and fine (except for your mod resistance which is not relevant for this). Much wiser to work with your vendor then manufacturer before opening it up. Expand Well the vendor (fast tech) have offered a partial refund if I get the thing repaired myself lol Link to comment Share on other sites More sharing options...
seekerom Posted October 10, 2017 Report Share Posted October 10, 2017 What are the termal settings for dna 75 hcigar nano? cooling time? heating time? Link to comment Share on other sites More sharing options...
