Aeckman Posted September 10, 2015 Author Report Share Posted September 10, 2015 So I'm still planning my DNA build and I was looking into using LED fire, up and down buttons. I'm somewhat new to the DNA boards but have made dozens of unregulated mods. Now, the fire button is momentary 3a/36vdc with a 2.8v LED and 15mA forward current. I figured I would just wire it to the positive and negative on the 510 so it would light up when fired. Would a 1/4v 270 ohm resistor protect the LED? Also the LED tact switches are 3v, 50mA forward. What size resistor would be needed and what would be the easiest way to wire those so that they will light up when pressed? Thanks Link to comment Share on other sites More sharing options...
VapingBad Posted September 10, 2015 Report Share Posted September 10, 2015 Brandon posted that there are 2 solder points on the board that can power the LED, I'll see if I can find the thread....here you gohttps://forum.evolvapor.com/topic/66518-topic/?do=findComment&comment=897999 Link to comment Share on other sites More sharing options...
Aeckman Posted September 10, 2015 Author Report Share Posted September 10, 2015 Thanks for the reply, I guess I'm confused still as I have read that thread too. It seems like there soldering it to the board? I'm looking to use tact switches with the LEDs built in. Or would I just use a 100 ohm resistor and solder the switches to the pads? Link to comment Share on other sites More sharing options...
blueridgedog Posted September 10, 2015 Report Share Posted September 10, 2015 Even with the LED built in, you will need to power the LED. From Brandon's instructions, put your resistor on the board, the grab power off of the opposite two solder points:If you look below the fire button you will see 4 small solder pads. Attach a 100 ohm resistor between the 2 pads on the left above the screen-printed 'F'. Resistor linkAbove the fire button, near the board edge and slightly off to the right, you will see 2 identical small solder pads. Attach your LED there, cathode side toward the middle of the board.That will give you what you want. Link to comment Share on other sites More sharing options...
