I have two different DNA200s, which have different cases and batteries and have to be careful not load the .ecig file from the other as it will assign the mod specific values (everything on the Mod tab) even though it is the other device ID and the result would be undesirable.  I would like to load and save non device specific settings without the risk of changing these values.  There are lots of ways to factor this, but I think that there should be a device type and prompt box before overwriting battery and device parameters as a safety device to stop inadvertently overwriting these on a different device.
In the same vein I feel non device specific settings should be independently handled, that would the be General, Theme and Screen tab setting.  Maybe a few check boxes for importing settings form another config would be the easiest to do quickly.
(You know it good when the suggestions are about fine details like this)
Escribe downloads the config in the mod you connect. I usually make changes and save to a file named <mod>.ecig (ie. HanaV200.ecig, BRD200.ecig). It's not that confusing.
Then you have to set all the other tabs manually for each mod, except Themes that can be saved separately.  But more important is inadvertently overwriting the battery and case setting by opening an ecig file from one of your other devices.
  • 1 month later...
Mangiman said:
Any body knows how to copy the settings from one dna chip to another ?
Save settings as a file from one and load settings when your other device is connected. Then upload to device.
Don't do that if they are different mods, especially if the battery is different or the mod resistance has been set, case analyser or battery analyser has been run without changing these settings.
I have a box with a 18650 mah 3s 100c lipo thats the one i need to get the same settings to load it in a hana v200 with 950 mah 3s LiPo. How can i change just the battery specs from the settings that i want to load??? Can it b possible?
Connect and download settings on Hana.
Write down the Mod Tab settings including the battery settings.
Connect and download settings from the mod you want to copy.
File->Save As.
Connect Hana, then File->Open the previously saved file.
Fill in the correct Mod/battery settings you previously wrote down.
Upload settings to second device.
