blank Posted October 20, 2015 Author Report Share Posted October 20, 2015 Hey I plan to build a DNA 200 in a 1590a CNC box. From the looks of it at most I could fit a 1000mah 3s battery. I'm concerned this won't suit my vape style battery life wise. I've searched but yet to see a 1590a 2S lipo setup. Has anyone found a battery to suit that would give more than 1000mah in 2S config. 1590a is as big as I want my box. The 200w vs 130w isn't too much of a concern as I could always toss in a 3s to experiment with TC. Do post your findings on best possible batteries in either 2s or 3s configurations in the 1590a (cnc or regular, as the Cnc box is slightly larger) If there any suggestions on other boxes that can be used that could fit better batteries any input is appreciated! And do post links of where I can find these items. I'm in Canada so if you know local sources do post it. Link to comment Share on other sites More sharing options...
VapingBad Posted October 20, 2015 Report Share Posted October 20, 2015 You need to compare batteries by Watt Hours to compare the probable run time for 3S Wh = mAh * 11.1/1000, for 2S Wh = mAh * 7.4/1000. So a 1000 mAh 3S would have about the same runtime as a 1500 mAh 2S. Link to comment Share on other sites More sharing options...
blank Posted October 20, 2015 Author Report Share Posted October 20, 2015 I already know about watt hour conversion. I was hoping on getting more higher capacity 2s than 1500mah. But you've made a valid point. Thanks! Link to comment Share on other sites More sharing options...
black lace Posted December 10, 2015 Report Share Posted December 10, 2015 did you manage to build this mod, I would love to see a shot if possible, Link to comment Share on other sites More sharing options...
