It will be about the same vaping time that a series box with 2 18650's will allow you.
1850mAh 3c LiPo = 20 watt/hrs
2 (2500mAh) 18650's in series = 18.5 watt/hrs
2 (3000mAh) 18650's in series = 22.2 watt/hrs
So, the Lipo falls right in between the two.  Very similar vape time between it and the 3000mAh 18650's.  That is assuming you can build or find a mod with a 1850mAh Lipo in it.
Also, keep in mind that the Lipo pack will likely be more stable with less sag at 100W.
I can vape all day at 30 watt twin coils on a 1300mah lipo not in temp mode,  i reccon in temp mode i would get a lot better performance out the battery,  i probly use 10 /12 ml of juice in a day,
i would say doubtfull,   at 100 watt on a 1500 lipo, and re think my coils, to a bit smaller but same heat your after, but would bring the power down a bit..
what do you vape on at that?
I appreciate all the replies-and it's true that it charges fast. I actually found a company, Vaporlips I think, that custom builds dna200's. They claim to have a 3000mHa battery. Is that as good as it seems, or should I be wary?
have only heard good things on here about Vaporlips, rule of thumb is x3 on lipo mah compared to 18650's, so to match a 3000 mah lipo with 18650's you would need to find 3 x 3000mah = enough to get 9000mah, hope that aint as clear as mud but not getting to scientific a lipo is three times moor efficient.
I have built mods using the max amps 1850mah 100c lipo and at 150watts I can Vape Vape the entire day and most of the night. I also work in a shop so my mod pretty much never leaves my hand.
also this thread running on different mods, attys and life span may be of some use, item 8
unfortunately he doesn't list the batterys in each mod but it shouldn't be to much hassle to search it
https://forum.evolvapor.com/topic/67550-topic/?do=findComment&comment=907928
