Hello!
I have this problem. If you leave the unit after using for a while, the device goes into sleep mode. To wake up the fee has to be connected yusb. The device does not wake up when you press the fire. It has so conceived or Problem?
Try updating firmware. Mine is behaving just like that, but i have Warranty message after being connected to escribe, and besides that it is charging at 0.09A and getting warm - So i suppose new VS to come... The second one. This one has maybe 2 weeks (more or less the same time than previous one, and both them was from same date) Maybe a bad batch?
I have the sleep issue as well, seems like the device is just dead until plugged into a usb cable.  It does seem fairly warm during charging and tends to stay warm for as long as it is plugged in, even after charging is complete.
My Hcigar Vt200 is doing the same, its always warm when plugged in even if it is fully charged. If I dont use it for 2-15min, the screen goes off and needs to be plugged in for it to wake up.
My other dna200 from vapecige has been working perfectly.
[x2j8Lfc]
Photo of the temperature after it has been plugged in for 24 hours or so, not used, board is at 97F in full idle, my other mod is 85F even when in frequent use.
[JCzpWbq]
https://forum.evolvapor.com/topic/67027-topic/?do=findComment&comment=903151
Sos, am on mobile away from computer presuming youve allready done disconnect re connect battery and firmware update...looks like the outcome of most vt200 problems relating to battery and screen, in a nutshell, they got replaced not fixed...
I have tried troubleshooting, on my own.
This issue was fixed on the newer boards I received from Evolv dated November previous boards are made in august.
It's a board issue as my own DIY got the same problem, after RMA every thing works fine.
