robmurray77 Posted November 27, 2015 Author Report Share Posted November 27, 2015 Tried to charge my wismec with a 1amp USB with LG HB2. They were about 40 to 50 percent. The charge symbol showed but after checking the unit aftet 6 to 7 hrs no change in charge. Any ideas? The unit had the battery test run on it with them in it so setting should be good. Link to comment Share on other sites More sharing options...
XenonRam Posted November 27, 2015 Report Share Posted November 27, 2015 robmurray77 said: Are you using the supplied USB cable? (The one that came with in the box with the Reuleaux.) Is the 1A supply you're using your computer USB port, or a wall wart? If you're not using the supplied cable, you should be because a lot aren't capable of the higher current. If you are using the supplied cable, try another cable you have around the house; the thickest one you have. If that doesn't work, pick up a high current USB cable off eBay. (Make sure it is a charge & data cable; or a charge only cable since you aren't having a problem with data transfer. Some are data only.) Also try a 2.0-2.5A wall wart. Use the device monitor in the eScribe program to help you monitor and diagnose the problem. Hope that helps. Link to comment Share on other sites More sharing options...
robmurray77 Posted November 27, 2015 Author Report Share Posted November 27, 2015 Yes it was the supplied USB cable. I will try a larger wall wart. The same cable and charger does charge my wife's unit. Maybe I will try a reset on my unit and see if that does anything as well Link to comment Share on other sites More sharing options...
Jaquith Posted November 27, 2015 Report Share Posted November 27, 2015 robmurray77 said:Tried to charge my wismec with a 1amp USB with LG HB2. They were about 40 to 50 percent. The charge symbol showed but after checking the unit aftet 6 to 7 hrs no change in charge. Any ideas? The unit had the battery test run on it with them in it so setting should be good.The no change is disturbing, as mentioned not all USB cables are the same but connection, charging rate (Amps), Battery Profile and cell condition all can play a role. Ideally you want to see 0.9X Amps, and >4.X Volt charging.In the Screen tab of Escribe, note the original settings, and for now I'd recommend: Battery Charge %, USB Voltage, and USB Current plus Charging Brightness of >25%. Before charging more, connect and run Escribe, attach an Atty; click Device Monitor and in the bottom right click on the 'Puff' and run it for a few seconds as shown below. All 3 Cells 'should' have very close Voltage changes with no apparent big gaps. Example of all good cells: Example of a bad Cell, Cell 1: Link to comment Share on other sites More sharing options...
steeno321 Posted November 27, 2015 Report Share Posted November 27, 2015 I am having the same issue with mine. Mine is giving me this on device monitor currently. Any help would be great. Link to comment Share on other sites More sharing options...
VapingBad Posted November 27, 2015 Report Share Posted November 27, 2015 That was an example of a bad connection to a cell, before deciding if one cell is bad swap thier positions and see if the weak cell is still the same physical cell (18650) or same position ("Cell n" in Escribe).Cell numbers for realeaux from above Link to comment Share on other sites More sharing options...
morgo Posted January 20, 2016 Report Share Posted January 20, 2016 Did you end up fixing this Link to comment Share on other sites More sharing options...
VapingBad Posted January 20, 2016 Report Share Posted January 20, 2016 I had no problem with mine, but some were fixed by tweaking the ground screw under the white foam plug in the battery cradle. Link to comment Share on other sites More sharing options...
morgo Posted January 23, 2016 Report Share Posted January 23, 2016 I can connect to escribe but wont charge. its showing 0.001a Link to comment Share on other sites More sharing options...
dwcraig1 Posted January 23, 2016 Report Share Posted January 23, 2016 What's the voltage of the individual cells? Link to comment Share on other sites More sharing options...
morgo Posted January 23, 2016 Report Share Posted January 23, 2016 all showing 3.80 on device monitor Link to comment Share on other sites More sharing options...
dwcraig1 Posted January 23, 2016 Report Share Posted January 23, 2016 Well that leaves out the "too low to charge" situation.It is set to Lithium Polymer and not LiFePO4 correct? Link to comment Share on other sites More sharing options...
morgo Posted January 23, 2016 Report Share Posted January 23, 2016 Yes set to lipo Link to comment Share on other sites More sharing options...
morgo Posted January 23, 2016 Report Share Posted January 23, 2016 I've tried everything Link to comment Share on other sites More sharing options...
dwcraig1 Posted January 23, 2016 Report Share Posted January 23, 2016 Have you verified that the cord and the USB port are both working properly by charging another device? A cell phone perhaps. Or try another cord and power source. Link to comment Share on other sites More sharing options...
morgo Posted January 23, 2016 Report Share Posted January 23, 2016 I've tried all different cords and different wall plugs just incase it was the laptop Link to comment Share on other sites More sharing options...
dwcraig1 Posted January 23, 2016 Report Share Posted January 23, 2016 There should be more folks more knowledgeable on the matter than myself responding soon hopefully.You might try a hard reboot, not sure if it would help but probably isn't going to hurt anything, works with Iphones. Link to comment Share on other sites More sharing options...
morgo Posted January 23, 2016 Report Share Posted January 23, 2016 OK thank you for your help mate Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted January 23, 2016 Report Share Posted January 23, 2016 don't know if this has already been suggested but......in device mon what happens when click 'reset usb current limit' under the diagnostics tab? or you type in 500 in the 'set usb current limit' option? Link to comment Share on other sites More sharing options...
morgo Posted January 23, 2016 Report Share Posted January 23, 2016 I have tried the reset USB current limit but I haven't tried to put 500 in I will try that next and report back Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted January 23, 2016 Report Share Posted January 23, 2016 morgo said:I have tried the reset USB current limit but I haven't tried to put 500 in I will try that next and report backthe thing is when you click the 'reset the usb current' option , it should do just that. go ahead and type in 1 for the usb current setting. once again don't know if this was mentioned further back........have you tried a hard reboot, reflash the newest firmware, or different batteries? could it be your usb cable? have a bunch more to try out with a 1 amp wall wart?what kind of batts are you using that are coming out to over 34 watt hours? if they're 3000 mah batts try 28 watt hours. see if that does something. you should run batt analyzer, (if u haven't already.) Link to comment Share on other sites More sharing options...
morgo Posted January 23, 2016 Report Share Posted January 23, 2016 Hello mate I was using efest 3100 that come with it. I bought LG 3000 today waiting for them to fully charge then I'm going to try them. I have done a reflash with the newest firmware for some reason the hard reboot will not work. I've tried a number of different cables and wall charger I'm going to try the new battery's got my fingers crossed. Thanks for your help I will be lost without the help of you guys on here Link to comment Share on other sites More sharing options...
