For the past few days my mod has been switching to power mode when using NiFe 30
Not particularly a worry given the material however it has ruined cotton.
just recently the profile decided to use 199w as it's starting wattage before switching to the 85 I have it set for
for some reason the following steps work as a work around
  • switch to a titanium profile
  • fire in temp for titanium
  • return to NiFe
  • when coils are cool lock ohms
I decided to reset my device and remake the profile so we will see how that fairs.
Device is a tuglyfe
attached is previous profile
14Feb2016.ecig
been having the same sort of issue myself dude.
Has this happened since the update?
I have noticed my only custom profile doesn't fill the graph from the start, it starts after a little gap, i noticed yours don't either. (don't take that as the reason as i have asked the question myself)
Are they SteamEngine profiles?
Im just trying to put 2+2 together to see if i can find out why. o.O
It is a common issue, especially with lower TCR wires, to decline to fire in TC mode.  As VB pointed out above, that simply means that the chip failed to see the 150 degree change and assumed it was non-TC wire.  95% of the time this is a loose leg or a hot spot.
