MIsterious Vaper Posted June 25, 2016 Author Report Posted June 25, 2016 i have the wismec dna200 using a griffin with dual fused claptons 0.18 ohm i have it set at 80 watts but when i fire it reads 79.1 watts i set to 85 watts and fire at 84.1 it is always 0.9 watts lower then what i have it set at also useing samsung 25r batteries i have three sets and this happens with all
retird Posted June 25, 2016 Report Posted June 25, 2016 Can you put up a screenshot from Device Monitor while firing at 80 watts?
retird Posted June 25, 2016 Report Posted June 25, 2016 From the graph it looks like the wattage is regulating with peaks above 80 watts and valleys below 80 watts so it is reaching 80 watts. Any hot spots in your coils and are they spaced coils? Coil connections tight? What results do you see if using just a single Kanthal coil?
dwcraig1 Posted June 25, 2016 Report Posted June 25, 2016 Just curious, what is your soft cell cut off setting?
MIsterious Vaper Posted June 25, 2016 Author Report Posted June 25, 2016 soft cut is 3 volts coils are not spaced and no hot spots but this happens even with a full charge and haven't tried a single coil out yet getting similar results with my avocado 24 with 0.2 ohm build but 0.6 watt differance on the display of the mod
MIsterious Vaper Posted June 25, 2016 Author Report Posted June 25, 2016 i am wonder from mech mod experience could it be the atty them self with some kind of difference like a voltage drop or something
retird Posted June 25, 2016 Report Posted June 25, 2016 When I use a Kanthal Clapton (single coil) in power mode the wattage via Device Monitor always rises to wattage setting and flat lines there within .01 or .02 above or below wattage setting. My best guess without physically being able to troubleshoot is either the coils, the connections, or poor grounding in the device. I always use spaced coils. Know that I'm not much help but these are my thoughts. If I recall you posted the same issue back in May. Might also try cleaning the 510 pins of the device and atty's...and the threading... good luck...maybe others will have a thought that may help ya....
MIsterious Vaper Posted June 25, 2016 Author Report Posted June 25, 2016 i have had this mod for about 7 months now i know the 510 connection is kind of stuck down i guess it time to replace and upgrade it thank you for the help
BillW50 Posted June 25, 2016 Report Posted June 25, 2016 My two Reuleaux DNA200 510 pin measures from top of pin to the base of an atomizer:Pin up: 3.9mmPin dw: 4.6mmIf yours is within that range, it is still good. With long 510 atomizers, I use mod guards like these (they are 0.4mm thick):http://www.kidneypuncher.com/kp-mod-guard-5-pack/
MIsterious Vaper Posted June 25, 2016 Author Report Posted June 25, 2016 mine is pretty much stuck down some of my attys wont work cause it stuck down pretty much have to use one of my heat sinks to get most to work so i guess i just gona replace it with a new upgrade when i get the chance to
BillW50 Posted June 25, 2016 Report Posted June 25, 2016 If you are not going to keep it, I would sell it. Surely it is worth something.
MIsterious Vaper Posted June 25, 2016 Author Report Posted June 25, 2016 i going to keep the mod i love it just replace and upgrade the 510 connection
BillW50 Posted June 25, 2016 Report Posted June 25, 2016 That is what I would do. Hell I hate my RX200 mods and I would rob the 510 out of them to repair a Reuleaux DNA200 in a heartbeat.
MIsterious Vaper Posted June 25, 2016 Author Report Posted June 25, 2016 i am think of using a low profile fat daddy 510 for the replacement
BillW50 Posted June 25, 2016 Report Posted June 25, 2016 The L frame for the Wismec 510 holder will need to be cutoff. And you might need to cut into the battery sled to make it fit.
MIsterious Vaper Posted June 25, 2016 Author Report Posted June 25, 2016 i will figuer it out in the meen time just going to order a triaid for now
BillW50 Posted June 25, 2016 Report Posted June 25, 2016 I love my two Triades. Batteries fit very tight though. It is best instead of centering the negative of the batteries first, just put them in by just barely on the edge and get the positive in there first (while pushing against the spring), then push the negative in the rest of the way. Otherwise the batteries will be inserted with too much of a slant and won't fit. Same idea coming out, but in reverse.
