johara45 Posted August 5, 2016 Author Report Posted August 5, 2016 I'd like to apologize in advance if this question has already been answered or if it's all together just dumb, but has anyone tried mixing titanium wire with say kanthal? I'm thinking of trying to fuse Clapton titanium wire but can't locally find higher gauge wires above 26 ga in titanium so was thinking of using kanthal for the outer wrap.
aonoukraine Posted August 5, 2016 Report Posted August 5, 2016 The wire you using for outer wrap in Clapton doesn't matter. It does not affect neither resistance nor TFR curve. Check my words on steam-engine;-)
johara45 Posted August 5, 2016 Author Report Posted August 5, 2016 So for temp control the kanthal won't affect the devices ability to regulate the temp for the titanium wire? Sorry not sure I fully understand the concept of mixing wires.
BillW50 Posted August 5, 2016 Report Posted August 5, 2016 Well with a fused Clapton, the outer wire is like 15 times longer than the inner wire. If they were the same wire, the outer would be 15 times higher resistance than the inner wire. That would lower the whole thing just a tad lower than just the inner alone. Not too much of a difference. Although the difference between a thicker wire titanium (which is a low resistance wire anyway) with a smaller 15 times longer (very high resistance) Kanthal, as far as temperature control goes, it won't even see it.
johara45 Posted August 5, 2016 Author Report Posted August 5, 2016 Ahhh ok thanks guys for the information and explanation, guess I will try it tonight, hopefully the titanium tcr won't have to be manipulated
aonoukraine Posted August 5, 2016 Report Posted August 5, 2016 I use SS316 as core wire for my claptons and kanthal as a wrap. Even though SS has much lower TCR than titanium, everything works fine with standard curve. So feel free to experiment;-)
johara45 Posted August 5, 2016 Author Report Posted August 5, 2016 Thanks aonoukrain, that wire combination also crossed my mind, only thing that I was afraid of that I never had too much success in controlling the stainless steel wire types the vape always seemed a bit cold when vaping at least for me it was. I would have to pretty much have temp set at max to get the warmth that I was looking for. What is the settings that you use? I had mine set at 316l ss wire set at 50w with punch and preheat set to minimum. Think it was 0,0,1s something like that.
aonoukraine Posted August 6, 2016 Report Posted August 6, 2016 I like when my coils heat up instantly, so preheat power is usually maxed out and punch is set to 3-5 for 1sec. You should play with coil calculators every time you wrap a new coil to configure your power and achieve heat coefficient between 0,20-0,30W/mm^2 (I prefer 0,30)
Jentz9517 Posted August 6, 2016 Report Posted August 6, 2016 johara45 said:Thanks aonoukrain, that wire combination also crossed my mind, only thing that I was afraid of that I never had too much success in controlling the stainless steel wire types the vape always seemed a bit cold when vaping at least for me it was. I would have to pretty much have temp set at max to get the warmth that I was looking for. What is the settings that you use? I had mine set at 316l ss wire set at 50w with punch and preheat set to minimum. Think it was 0,0,1s something like that.Johara Try these for ss316l they run warmish and are great for mixed alsoJJSSv2.csvJJ_SSv1.csv
johara45 Posted August 6, 2016 Author Report Posted August 6, 2016 Thanks much guys! The csv's I will definitely give it a go, and will also try and mess with coefficients I never knew what that was all about and still don't, but now at least I have a ball park of what to start with thanks again guys will report back after I dial things in.
