Non-TC modes
Now we have two ways to use VW mode: setting the temperature to OFF, or using a non TC material. I am usually doing the former, as it shows watts on the main screen, and I noticed so far is that it's possible to use a pre-heat with the "temperature OFF" method, but not with the material one.
I was wondering if there was any other difference between thoses two ways.
I don't use pre-heat so maybe I'm wrong, but at least I noticed that when you set a TC material, and select "Off" for the temperature in escribe, it still shows the preheat settings, while it disapears when selecting a non-TC material.
I believe they work the same as preheat needs temp sensing and doesn't even get used until the board is sure you have a temp sensing coil fitted.  The non temp sensing wire is a new feature and it is probably that they didn't get time to hide the preheat settings when you click off.
