germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 yeah my laptop came with avg and the lifetime key so its what ive been using. But malwarebytes is an light weight program and scan pretty fast for the full complete scan. it just sucks i cant use escribe lol, i finally got and dna 200 and this happens. this vt133 is a really nice dna battery life last me full day. was hoping to customize it tho. Link to comment Share on other sites More sharing options...
dwcraig1 Posted August 31, 2016 Report Share Posted August 31, 2016 You might try uninstalling EScribe and reinstalling with AVG disabled. Link to comment Share on other sites More sharing options...
germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 already try that avg is quite a problem at times with some games it think everything is an threat. only thing i can think of is starting from fresh really dont want to do that tho. I rather buy a cheap small note book just for escribe lol. Link to comment Share on other sites More sharing options...
VapingBad Posted August 31, 2016 Report Share Posted August 31, 2016 Have you looked in the application event log? Also I wonder is any disabled services may affect it, my start menu would not open, notifications were not working plus a few other things in Win 10 with the firewall disabled. Also you could try .net fusion logging https://msdn.microsoft.com/en-us/library/e74a18c4(v=vs.110).aspx Link to comment Share on other sites More sharing options...
retird Posted August 31, 2016 Report Share Posted August 31, 2016 Curious where you downloaded EScribe from and is it the English, German, or other version? Language of computer and are any language packs installed? Link to comment Share on other sites More sharing options...
germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 At Vapingbad the application event log: what is that At retird i downloaded it from and thread in this forum and from the evolve website, Link to comment Share on other sites More sharing options...
VapingBad Posted August 31, 2016 Report Share Posted August 31, 2016 germanguy45 said:At Vapingbad the application event log: what is that At retird i downloaded it from and thread in this forum and from the evolve website,Control panel - administrative tools - event viewer - application logIt varies between windows versions, just have good look at errors and warnings. Link to comment Share on other sites More sharing options...
germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 VapingBad said:Control panel - administrative tools - event viewer - application logIt varies between windows versions, just have good look at errors and warnings. ok sweet I'll look through it and report back what I see Link to comment Share on other sites More sharing options...
germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 this is what it says Faulting application name: EScribe.exe, version: 0.0.0.0, time stamp: 0x57a929afFaulting module name: clr.dll, version: 4.0.30319.34209, time stamp: 0x5348961eException code: 0xc0000005Fault offset: 0x00032bd1Faulting process id: 0x125cFaulting application start time: 0x01d203b1112e2b2cFaulting application path: C:\Users\Admin\AppData\Roaming\Evolv\EScribe Suite\EScribe.exeFaulting module path: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dllReport Id: 4f735e71-6fa4-11e6-a33d-5c260a2b3adcApplication: escribe.exeFramework Version: v4.0.30319Description: The process was terminated due to an internal error in the .NET Runtime at IP 6A662BD1 (6A630000) with exit code 80131506. Link to comment Share on other sites More sharing options...
VapingBad Posted August 31, 2016 Report Share Posted August 31, 2016 That is the MS dot net common language runtime engine, it confirms that EScrib is encountering an error but not what it is, probably a version mismatch between EScribe and another component it uses. Try running the installer again with just services packs checked in the install options. Link to comment Share on other sites More sharing options...
germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 ok i just tried it and its an no go, still not opening. wish it told what the error specifically is. Link to comment Share on other sites More sharing options...
VapingBad Posted August 31, 2016 Report Share Posted August 31, 2016 It could be almost anything https://www.google.co.uk/search?num=100&newwindow=1&q=.NET+Runtime++exit+code+80131506&oq=.NET+Runtime++exit+code+80131506&gs_l=serp.12...12495.14072.0.15343.2.2.0.0.0.0.75.146.2.2.0....0...1c..64.serp..0.0.0.4lDT6H5s-hIAre you running it in a language other than English, if so you try changing the Local to English the see if the translation is an issue. Link to comment Share on other sites More sharing options...
germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 its in English as im in the states, the downloads are also English. i may have to completely wipe my computer and start fresh. i think everyone is running out of ideas lol. Link to comment Share on other sites More sharing options...
retird Posted August 31, 2016 Report Share Posted August 31, 2016 Have you thought about restoring your computer back to a date prior to your first install of EScribe? If your restore points go back that far? Then download EScribe and try it again... Link to comment Share on other sites More sharing options...
VapingBad Posted August 31, 2016 Report Share Posted August 31, 2016 Try the Visual Basic 6 runtime https://www.microsoft.com/en-us/download/details.aspx?id=24417 it is a long shot, but one of the components EScribe uses may use something that references that. Also the Visual C++ redistributable, but ther are lots of releases http://www.howtogeek.com/256245/why-are-there-so-many-microsoft-visual-c-redistributables-installed-on-my-pc/ there are links to the packages near the end, the x86 ones would more likely be referenced by components.Both long shots, but if you are thinking about wiping your PC and starting over... Link to comment Share on other sites More sharing options...
germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 yea i did that using system restore, i got a restore point from like 5 days ago i use that one. Link to comment Share on other sites More sharing options...
germanguy45 Posted August 31, 2016 Author Report Share Posted August 31, 2016 VapingBad said:Try the Visual Basic 6 runtime https://www.microsoft.com/en-us/download/details.aspx?id=24417 it is a long shot, but one of the components EScribe uses may use something that references that. Also the Visual C++ redistributable, but ther are lots of releases http://www.howtogeek.com/256245/why-are-there-so-many-microsoft-visual-c-redistributables-installed-on-my-pc/ there are links to the packages near the end, the x86 ones would more likely be referenced by components.Both long shots, but if you are thinking about wiping your PC and starting over... will try this and report back Link to comment Share on other sites More sharing options...
germanguy45 Posted September 1, 2016 Author Report Share Posted September 1, 2016 still no luck, I don't see no other solution then to wipe and start over. going to give it another few days or so lol. Link to comment Share on other sites More sharing options...
germanguy45 Posted September 2, 2016 Author Report Share Posted September 2, 2016 well I got it to work, it turns out that I got an bad download multiple times. so i downloaded from my friend house and transfer it to my laptop and bam works. I just have another problem now anytime I turnsikesory and download something or upload something I get a error. it's saying failed to detect eeprom or something like that Link to comment Share on other sites More sharing options...
dwcraig1 Posted September 2, 2016 Report Share Posted September 2, 2016 Did you install EScribe on your friend's computer and try using it there as well, did you get the errors too? Link to comment Share on other sites More sharing options...
germanguy45 Posted September 2, 2016 Author Report Share Posted September 2, 2016 dwcraig1 said:Did you install EScribe on your friend's computer and try using it there as well, did you get the errors too? yeah I got same errors, what does eeprom mean anyways? Link to comment Share on other sites More sharing options...
dwcraig1 Posted September 2, 2016 Report Share Posted September 2, 2016 Electrically Erasable Programmable Read-Only Memory https://en.wikipedia.org/wiki/EEPROM Link to comment Share on other sites More sharing options...
germanguy45 Posted September 2, 2016 Author Report Share Posted September 2, 2016 dwcraig1 said:Electrically Erasable Programmable Read-Only Memory https://en.wikipedia.org/wiki/EEPROM hmm interesting, from looking on the forums here i see it can be a cable problem. I'm using the cable that it came with so could it be an faulty cable? Link to comment Share on other sites More sharing options...
dwcraig1 Posted September 2, 2016 Report Share Posted September 2, 2016 You should for sure try another cable. Link to comment Share on other sites More sharing options...
germanguy45 Posted September 2, 2016 Author Report Share Posted September 2, 2016 dwcraig1 said:You should for sure try another cable. well just try 3 more cables and same thing. I know they work transferring stuff., I tested them before hand. I'm leaning towards something else on my laptop lol. Link to comment Share on other sites More sharing options...
