masonjarvapes Posted August 15, 2015 Author Report Share Posted August 15, 2015 maybe this has been covered but i noticed that you can wire up remote buttons for the fire, + and -. If you use those, do you have to remove the buttons already on the pcb or will it still work? Link to comment Share on other sites More sharing options...
reeder359 Posted August 15, 2015 Report Share Posted August 15, 2015 I'm wondering the same thing. I just ordered my buttons and 510 connector. I'm putting the whole set up in a hammond 1590b box mod and was wondering about all the soldering. I don't want to use the on board buttons because I want this to be a very durable long lasting mod. So of there's anyone that could help it would be great with all the wiring and soldering. Thanks Link to comment Share on other sites More sharing options...
blueridgedog Posted August 15, 2015 Report Share Posted August 15, 2015 There are solder point for off chip buttons. On-chip buttons can be left in place if you use them. Link to comment Share on other sites More sharing options...
Willy Posted August 16, 2015 Report Share Posted August 16, 2015 reeder359 said:I'm wondering the same thing. I just ordered my buttons and 510 connector. I'm putting the whole set up in a hammond 1590b box mod and was wondering about all the soldering. I don't want to use the on board buttons because I want this to be a very durable long lasting mod. So of there's anyone that could help it would be great with all the wiring and soldering. ThanksI think you might be surprised at the life ratings these switches have, if you asked John or Brandon they will probably give you a link to the product page of the switches used on these 200 boards. It would be interesting to compare the life ratings to the popular clicky dome tactile switches. Link to comment Share on other sites More sharing options...
turbocad6 Posted August 16, 2015 Report Share Posted August 16, 2015 the dome tact's are not waterproof I searched for waterproof micro switches like this and never found anything good. these are said to be waterproof, meaning there def not just the cheapest switches, there probably higher quality than the ball tact's really would be my guess. Link to comment Share on other sites More sharing options...
masonjarvapes Posted August 16, 2015 Author Report Share Posted August 16, 2015 I have something special in mind, my question to DNA is can I order one without the switches installed? Link to comment Share on other sites More sharing options...
scoopy Posted August 16, 2015 Report Share Posted August 16, 2015 Whether they put the buttons on or not u can still connect your choice of buttons and connect them to the thru hole pinouts on the side of the board....u can leave the original buttons on and still use the aftermarket buttons with no problem......unless u absolutely have to have the original ones off that's a different story Link to comment Share on other sites More sharing options...
masonjarvapes Posted August 16, 2015 Author Report Share Posted August 16, 2015 I'd rather not have the buttons on the board for accidental pushes if something shifts around Link to comment Share on other sites More sharing options...
turbocad6 Posted August 16, 2015 Report Share Posted August 16, 2015 you can't order one chip that way. you might be able to order 300 or 500 of them with a special request like that but the only practical way to do one is to remove them after if you must have them off Link to comment Share on other sites More sharing options...
Guest Posted August 21, 2015 Report Share Posted August 21, 2015 turbocad6 said:the dome tact's are not waterproof I searched for waterproof micro switches like this and never found anything good. these are said to be waterproof, meaning there def not just the cheapest switches, there probably higher quality than the ball tact's really would be my guess.they look no different then the ones on the board Link to comment Share on other sites More sharing options...
Brandon Posted August 25, 2015 Report Share Posted August 25, 2015 We use waterproof Omron buttons (IP67) on the 200. Rather than remove the buttons, you could remove the button enclosure and rubber actuator which would be easier and protect against accidental button presses. Link to comment Share on other sites More sharing options...
Brandon Posted August 25, 2015 Report Share Posted August 25, 2015 And the onboard buttons are rated to 100,000 operations minimum. Link to comment Share on other sites More sharing options...
turbocad6 Posted August 25, 2015 Report Share Posted August 25, 2015 the cheap little bb type buttons are NOT ip67 rated which is why I think the onboard buttons are probably better than the external bb buttons, and they do feel better to me than the bb's Link to comment Share on other sites More sharing options...
Guest Posted August 26, 2015 Report Share Posted August 26, 2015 The STJ series buttons are ip67 rated but I'm still looking for a vender. There's something about the dome tactile that I like. But yeah to each there own. Link to comment Share on other sites More sharing options...
turbocad6 Posted August 26, 2015 Report Share Posted August 26, 2015 I like the dome tact's, use them all the time, just wish they were waterproof. if you find any ip67 rated switches like these I'd like to know about them any links to these omron switches even ? Link to comment Share on other sites More sharing options...
Brandon Posted August 26, 2015 Report Share Posted August 26, 2015 Here is a link to the Omron Datasheet. It is model number B3SL-1002P. Link to comment Share on other sites More sharing options...
Guest Posted August 27, 2015 Report Share Posted August 27, 2015 Anyone want to go in on a group buy the company has a $50 minimum on the dome tactile switches ip67 We have stock on actuation force F130, and F200 in Silver Contact Material. STJF130Q Qty 10=$1.16 each, qty 100=$1.06 each Standard Lead-time 5-7 weeks Stock in our Minnesota Warehouse STJF200Q Qty 10=$1.16 each, qty 100=$1.06 each Standard Lead-time 5-7 weeks Stock in our Minnesota Warehouse STJF300Q Qty 10=$1.16 each, qty 100=$1.06 each Standard Lead-time 5-7 weeks STJF500Q Qty 10=$1.16 each, qty 100=$1.06 each Standard Lead-time 5-7 weeks Non Cancellable/Non Returnable http://www.citrelay.com/Catalog%20pages/Switches/STJ%20Series%20Catalog.pdf Link to comment Share on other sites More sharing options...
KTMRider Posted September 20, 2016 Report Share Posted September 20, 2016 Button life came up on ECF and I was curious to know. I thought it was 300,000 to 500,000. 100,000 isn't a lot. I already have 80,000 puffs on most of my DNA200's. Does anyone have more than 100,000 puffs on theirs? Link to comment Share on other sites More sharing options...
