I just received a VT133 as a present. I don't really have an interest in TC and would like to know what the proper settings in Escribe would be for my preferred setup. Are there any specific ecig files I can download for this or can someone share their settings?
  • VT133
  • Kanthal @ 0.5ohm
  • LG HG2 Batteries
  • Aromamizer
I may eventually try TC, probably with SS once I get used to this mod.
Thanks to Steve (Wingsfan0310) for creating the case analyzer part.
Case Cooling Time Constant: 356.58
Case Heating Time Constant: 429.86
Case USB Charge Temperature Rise: 6.39ºF
+ 17.62ºF/A
Minimum Ambient Temperature: -20ºF
Maximum Ambient Temperature 110ºF
Thanks much for those settings. Is there a file specifically for the battery settings?
BillW50 said:
The batteries depends on the batteries you are using. But the watt-hour calculator should work too.
Thanks. I'll using LG HG2s so I give the calculator a try.
BillW50 said:
Great! Remember the pack voltage is 7.4v (3.7v x 2). And use the capacity of one battery, don't add them up.
Thanks much! You've been very helpful. After playing around for a bit its not so intimidating.
In addition to the case analyzer information, does anyone have the mod resistance for the VT133? I've tried a few times to use a bit of copper to check, but the connection is never stable enough for me to get a good number in the atomizer analyzer.
While it would be better to check it properly as that can be useful info when looking for a problem you can expect it to be around 0.004 to 0.005 ohms when things are as they should be.
My last 200 came from a reputable place and the mod resistance was set to 0.02 ohms, they must have copied DJLsb's figures or something.
I checked it myself and got 0.004. Just saying.
I have a HCigar Vt133. I am trying to charge it via USB but it is not charing. I tried with a PSC and also with a 1 AMP plug but didn't charge. It gets recognized by the computer and I can update the firmware but it still doesn't charge. Please advise.
How do you know it isn't charging? The HCigar VT133 comes with the charging screen set to 0% (which is off). First, "Connect and Download Settings" (button) In EScribe under the screen tab, adjust the charging slider to 40% or higher. You can also change on this tab what displays on the screen when it is charging. Don't forget to "Upload Settings to Device" if you make any changes.
dcfluegel said:
rofl! nice, Mikey - ordered one of those rascals too, a couple days back (right after I caught the vt133 on sale at ecig) :)
Yeah, I didn't feel like making my own lol
Volcano tried to say the Lavabox's Resistance was .02 I believe, which is WAY too high!
Enjoy the VT133! I got one on the way :)
  • 3 months later...
+ 17.62ºF/A
Is this a general setting to use for the DNA 200? Should I use it?
dwcraig1 said:
This is the settings for Steve's Hcigar VT133.
What DNA200 mod do you have?
I have the vt133. Just got it the other day and I'm still trying to figure it out.. It doesn't seem to hit as hard as my fuchai. Set up the watt hours n what not.
  • 3 weeks later...
