Hi everyone.
I own 4 DNA200's that I absolutely love, and since the SP3 update, have switched to using 316L SS as I find this is perfect for my tanks (I am an RTA guy).
I use the standard SS 316 profile that comes with Escribe now to good results. I am just checking this is OK as I understand 316L is simply a low carbon version of SS 316.
Temperature seems to be within the range I would expect it too and the best wire I have isn't from a vape store, but a craft store-26G, and is perfect for single and dual coil builds at my power levels(30W or so, sometime pushing 40).
So, it is completely fine to use this setting with SS 316L isn't it? I would think so due to being able to use it in wattage mode0but I would rather be safe than sorry.
thank you all, Conan.
Yes, that's what I do, there is a minute difference between the temp sensing between 316 and 316L that is not worth worrying about 0.001 ohm on at 0.5 ohm coil at 200 C or 0.017% according to SteamEngine.
combatwombat said:
If you don't mind using 28 gauge wire, give 430ss wire a try, its more accurate than 316 and $10 for 200ft.
Advanced vape supply has high qualit spooled clapton wire in SS 430 now. 26 core, 30 wrap. Nickel free. Works phenomenally in temp control!!!!
