John la Posted October 24, 2016 Author Report Posted October 24, 2016 I need to remove the power button off the chip to make room for a nut. Is this possible? Or will I damage the board
dwcraig1 Posted October 24, 2016 Report Posted October 24, 2016 I guess that you aren't wanting to put it back. You can just remove the cover, disc and rubber part. On the DNA40 I snipped the four "legs" with no added problems, I would think to 200 would be the same but it might be good to wait for more answers.
John la Posted October 24, 2016 Author Report Posted October 24, 2016 Anyone else know if I can cut the tabs on the power button to remove it?
awsum140 Posted October 24, 2016 Report Posted October 24, 2016 I believe I read somewhere on this board that the switch is actually used as a "via" and connections are made across the common terminal of the switch. I am not an Evolv employee or and expert by any means, so take tis for what it's worth.
VapingBad Posted October 24, 2016 Report Posted October 24, 2016 The closest to an answer is this thread https://forum.evolvapor.com/topic/67577-topic/ but he replaced the switches so there is a small possibility that you may need to bridge some of the pads, but I as John didn't mention it probably not. With the 40 you definitely had to bridge two of the pads after removing the fire switch.
dwcraig1 Posted October 25, 2016 Report Posted October 25, 2016 I have two DNA40 boards here installed and working perfectly that have the fire buttons snipped off by using flush cutting pliers. Both work perfectly. I just pulled one of the buttons that I had cut off out of my desk drawer and checked it electrically, the two legs on each end of end of the switch are connected internally. When the button is pressed all legs are connected.Note that with the switch installed on the board the pads on the lower side (towards center) are battery voltage and when the button is pressed the two upper pads are supplied with battery voltage.So I checked one of the installed boards with the fire button cut off, only the one lower pad (the one on the "out" side of board) had battery voltage. The two upper pads both became "hot" when my external fire button was pressed.So I think it would work just fine but from what I see with this 40 it would be the two lower pads that might be better if bridged.Heck, on my other one I think I cut off all three buttons......Flask clone.
Rob_H Posted October 28, 2016 Report Posted October 28, 2016 You can remove it and use the remote pads for a new switch. It will not affect anything.
